Mirror removal...cable?
Hello!
What am I missing here...? I'm about to have my pCar painted and I'm stuck. How do you remove the cable from my electric mirrors? I took the entire mirror fixture apart (now an empty shell), but I can't see how to remove the cable and rubber without routing the cable back from the dash and door (PITA). Make sense? Any tricks to this seemingly simple task? ![]() Thanks! Tom
1978 - 911SC Targa 2005 - F150 2008 - XC90 Kaneohe, Hawaii
there is a special tool called a pin extractor that you can buy from Baum Tools Unlimited. Check out the Bentley manual for reference. I bought one about 3 years ago when I had some (ahem) cosmetic damage addressed on my drivers side door and fenders.
THANK YOU! So if I am reading/seeing this correctly; this tool assists you in removing the electrical pin contacts from the plastic jack housing? My goodness... Thanks, Tom
Brorag
I'm stuck the same way--did you get/use the tool?
are you done with it? Wanna sell it? jd |
I did it last weekend in prep for painting with needle nose pliers.....carefully.
'02 6GT2 - Weekend toy '04 6GT3 - Track weapon '13 Cayenne GTS - Daily duty '77 Yamaha RD 400 - Wheelie machine |
there are cheeper solutions that that tool Harbour freight might have it, i picked up a set that handeled most connectors for about $14.00. Will postpictures later.
LM |
I went to a local cheap tool place and bought a weird looking star shaped thing that had 8 or so different diameter pin extractor tools pointing out of the sides. Think it was some sort of GM tool but with a bit of care it worked to get my mirror electric connector pins out of the block OK. About 10 bucks if I recall correctly
'83 SC Coupe |
I was able to push the female connections out of the white plastic holder with a very small screw driver. Like the kind for eye glasses.
Silver 1980SC Euro coupe |
I'm with DavErb -
I think what he is describing is a basic rotating leather punch sold at most hardware stores. One of the hollow punch tubes fits over the pins/sockets and compresses the tabs so you can remove. The other (less elegant) solution is to cut and splice using solder and heat shrink tubing. Ron
1996 993 Coupe, Tiptronic, Polar Silver 1973 914 1.7 Marathon Blue Metallic - Sold 1977 911S Targa - Sahara Diamond Metallic - Sold 1975 911S Targa - Copper Brown Metallic - Sold |
for the future I bought a red many?pin Leslie mfg connector tool. I haven't used it yet but I think it's recommended around here for the mirror? It also says GM etc. Auto stores sometimes have Leslie mfg products on the spin displays. Good stuff.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Brorag
$65!!!!!!!!!!!!!!!!
Skip St.John
Baum Tools 1-800-848-6657 John, that is the ST1501/1511 and sells for $65.00 in stock. one thing to be careful of is to make a diagram of the plugs, it you notice the wires change color as they pass through the plug. ![]() thats nice.....................I'm rewiring w/radio shack plugs............ Last edited by Brorag; 12-17-2007 at 08:17 AM.. |
