Headlights only in high beam position
My 84 Carrera with H4's is permanently stuck with the high beams on regardless of the hi/lo switch position. I replaced the turn signal switch but the problem still exists. Fuses are ok. Any help or advise would be appreciated
Old 03-29-2007, 09:17 PM
2002M3Drew's Avatar
Send a message via AIM to 2002M3Drew
Do the fogs go on or are they off (because of the high beams)?
1983 911SC Coupe
1985 928S
1987 944 Coupe
1992 Carrera C2 Coupe
2006 Cayenne S
Old 03-29-2007, 11:30 PM
madmmac's Avatar
This should do it....bend and clean contacts.
http://forums.pelicanparts.com/show...rn+signal+stalk
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 03-29-2007, 11:40 PM
Nine9six's Avatar
Question: Did you install the H4's?
If so, did you wire in a relay kit so you wouldn't burn out the contacts turn signal switch?
If not, do a search on "sucro relay kit" or "Marcus Sucro". He sells a relay kit with instructions so easy, that even electrically challenged folks such as myself can install it.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-30-2007, 02:21 AM
Fogs don't come on
Old 03-30-2007, 07:13 AM
something like this happened to my 89 awhile back...turned out to be a small "bar" that gets bent in the stalk mechanism... I bent it back and all works fine...then I remember to not pull or push hard going from highs to lows.. and the "bar" doesn't get bent again.
Sold: 1989 3.2 coupe, 112k miles
Old 03-30-2007, 07:24 AM
dshepp806's Avatar
agreed: Stalk mechanism....
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-30-2007, 01:06 PM
2002M3Drew's Avatar
I agree...must be the stalk assembly. The electrics (at least this system) are fairly simple, and with the fogs not coming on, it appears the stalk is shorted and left in the high position. If you replaced, though, perhaps there is too much current and it burned out the new one?
Also, I don't know if this would cause it, but is it possible that the wires were placed on the new swich improperly? I know there are a bunch of them...I use the one-by-one transfer to the new part method...works for me.
1983 911SC Coupe
1985 928S
1987 944 Coupe
2006 Cayenne S
Old 03-30-2007, 01:24 PM
Nine9six's Avatar
Originally posted by Kelty911
Fogs don't come on
...Has nothing to do with the original post.
Lemme, say it a little slower....
If
you
installed
H4's
and
did
not
wire
in
relays,
you
will
repeatedly
burn
out
your
stalk
switch,
as
it
cannot
handle
the
increased
current
from
the
H4's!
96 993 C2 (Current)
Old 03-30-2007, 05:03 PM
darthracing's Avatar
Send a message via Yahoo to darthracing
Hey, if I smelled something nasty before/during my lights getting stuck in high-beam, do I assume a burnout?
Almost passed out from the fumes, got the windows down, was pretty scary - thought car fire!
Shouldn't the fuse have taken it first, or is the fail mode intentionally to not turn the lights out?
I don't know if relays exist, but H4's do. My fogs won't come on either, they were on when I popped on the highbeams.
Thanks,
Todd
86 Carrera Coupe (sold)
11 Nissan Leaf
03 Honda Civic Hybrid
91 ELECTRIC Kawasaki ZX-11
Old 12-16-2007, 11:51 PM
