Solvent recommendation needed
Can anyone recommend a solvent to remove the glue from double sided tape. This solvent must be paint/clearcoat friendly.
Thanks & Merry Xmas to all !SmileWavy |
Try a small amount of Rubbing alcohol...
Just about anything will remove that. 3M adhesive cleaner, WD-40, bug and tar remover...
JR |
Try with a heat gun as well. It helps.
Mineral spirits or paint thinner (NOT lacquer thinner) works well too ...
a couple of products, one called Goo Gone and one called Goof Off. or, if you have a lot to do. buy an eraser wheel for your drill from the auto paint supply.
Thanks fellas...
Naptha, aka lighter fluid, as in Zippo.
Not hot at all and won't harm paint |
| All times are GMT -8. The time now is 08:12 PM. |
