| Registered Join Date: Dec 2007
				 |  1987 911 Carrera 3.2 cold start blues...help!
			Hi Guys, First time posting here, I have a problem with my 1987 Porsche 911/993 conversion. I am running a 3.2 Carrera motor 47,000, new high pressure fuel hose, tune-up, plugs, distributor, battery, spark plugs, timing, oil seals, relays, etc. my car runs like a top, great idle and just flat out purrs...except on cold morning's, I can't get her to crank over!!! Early afternoon's and early evenings are just fine! Could this be some sort of 3.2 cold start issue, and if so what??? Last edited by P_O_R_S_C_H_E; 12-17-2007 at 06:05 PM.. Reason: just updated | ||
|  12-17-2007, 09:17 AM |
| Registered |
			No cold start valve or warm up regulator on 3.2's.    How long before the idle stabilizes?  Does it hunt or just run rough?
				__________________ DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" | ||
|  12-17-2007, 10:00 AM |
			Hi DonMo, When it finally starts it idles fine, kicks right over! This of course if it's warm. It doesn't hunt or run rough, the idle is steady. When it finally starts, it purrs... | ||
|  12-17-2007, 06:03 PM |
| Registered Join Date: Sep 2003 Location: PA of USA
			Welcome to the List. The first thing you might want to consider is replacing / updating the cylinder head temperature sensor to a two wire type... You might want to do the proverbial search (this is a common and much lamented problem)
				__________________ 1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') | ||
|  12-17-2007, 06:18 PM |
| just me |
			definitely check your cylinder head temp sensor. that helped with my cold starts also think about getting your injectors really cleaned. that will help too
				__________________ 1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ | ||
|  12-17-2007, 06:30 PM |
| Registered |
			I would do the CHT also, do a search on CHT and BMW and 3.2.  There is a BMW part that is the same as the Porsche for much less the cost.
|  12-18-2007, 02:11 AM |
			A little 'search help' will get you going here: Guest Technical Article: Cylinder Head Temperature Sensor - Upgrade http://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm A thread with pictures (Head Temperature Sensor Replacement) : Head Temperature Sensor Replacement
|  12-18-2007, 05:32 AM |
| Registered Join Date: Feb 2004 Location: louisiana
			I'd check the battery/alt before anything else
|  12-18-2007, 09:39 AM |
