gungadin's Avatar
ID this engine?
These numbers are on my engine.
The decal on the fan housing says 911SC
below on the right of fan
6392956
930/03
It's in a '76 911S.
Old 12-19-2007, 09:22 AM
PeterRT's Avatar
MY '79 RoW SC engine, 180 PS.
Old 12-19-2007, 09:43 AM
3.2 CAB's Avatar
This is a copy of what I posted to your other question about 12V coils.
The 930/03 engine number shows to be used in a ROW-1979 911SC with that engine number range. It also states that it did not have points from 1978 on. Apparently someone changed it to a point type ignition at some time in the past. The engine serial numbers started at 6390001-on. The 1978 serial number range started at 6380001 - on. Hope this info helps. Good luck!!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-19-2007, 11:22 AM
