-   -   Replacing steering wheels (http://forums.pelicanparts.com/porsche-911-technical-forum/38330-replacing-steering-wheels.html)
targa88 03-10-2001 11:55 AM
I am looking to replace my OEM steering wheel. Some other owners have suggested Momo or Sparco. Any recommendations and size requirements(diameter). Also to remove the existing wheel,is there some trick to extracting the horn pad. Thanks
Stephan Wilkinson 03-10-2001 12:01 PM
To remove the horn pad, you simply pull it straight out from the wheel. Make sure you pull it _straight_ out, not cocked, and if you need to use something to pry it, be sure you exert as much equal pressure as possible opposite the point where you're prying. The amount of pull it may take might surprise you, but the horn pad is held in place simply by the "spring" pressure of receptacles that grip three (in the case of my SC)small posts. There's nothing else holding the horn pad--no screws, no bolts, nothing.
Stephan
Mikkel 03-10-2001 12:22 PM
I have a 350mm Momo in my 84 Carrera 3.2
I think it fits perfectly in the 911 cabin design. Also the slightly smaller diameter gives you more steering feel. But I have to admit that it also steals the view to the gauges. See the picture I've e-mailed.
rstoll 03-10-2001 12:28 PM
I have a Momo Competition in my '83 SC. I like the look and feel, but you do have to look around it to see the guages.
Robert Stoll
83 SC
83 944
targa88 03-10-2001 01:29 PM
<font face="Verdana, Arial" size="2">Originally posted by Mikkel:
</font>
Great picture. Where di you get the porsche centerpiece, since I don't believe that it is a stock Momo item?
Doug Zielke 03-10-2001 04:57 PM
I was thinking of getting the 930-style wheel from A-J USA. It looks Factory with the enamalled Porsche crest in the center. See their website for a picture.
Doug
'81 SC Coupe
Canada West Region PCA
JackOlsen 03-10-2001 05:31 PM
The AJ-USA wheel is great, just a little pricey. Click here to see it in a 73 interior.
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
josh912 03-10-2001 07:11 PM
I'm going to go against the flow here. KEEP the OEM steering wheel! I just replaced my broken MOMO with an OEM steering wheel and have NO regrets whatsoever! The car has a better feel, you can see ALL of the gauges in their entirety, and it looks more original and for that case better.
Joshua Harrison
1968 912 Coupe
Doug Zielke 03-10-2001 07:34 PM
Yeah Jack, that's the one!
Very good looking....time to plunder the checking account again!
Doug
'81 SC Coupe
orbmedia 03-10-2001 07:51 PM
I have to agree with Josh. Momos are great for occasional use and competition use, their smaller size makes effectively shortens the steering ratio. But for street use, I find the OEM wheel is the most comfortable.
campbellcj 03-10-2001 08:38 PM
Personally I can't stand the early OE wheels -- way too huge (can you say "bus"?) and skinny.
I have a Momo Monte Carlo on my 914 and a Nardi/Personal "Fittipaldi" on my 911. Love them both.
Whatever you do, KEEP the original steering wheel in case you sell the car or decide to return it to stock!
targa88 03-17-2001 06:18 AM
Thanks for the help. I ended up purchasing and installing a MOMO Millenium steering wheel. It is a little smaller than the original wheel without obstructing too many of the gauges. The only issues is that you loose the locking mechanism and the horn is virtually impossible to connect.
But it looks better and handles better. Definitely an improvement.
