G50 Woes
Wondering what the problem is with my tranny.somethhing in there is very loose,there is a vey loud clunk whenever I either put my foot on or off the gas althoughit shifts and drives great.any ideas?thanks in advance,Marty
Old 06-28-2008, 09:03 AM
ianc's Avatar
Clutch? CV's? Wheel bearings?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 06-28-2008, 09:34 AM
All that seems fine,when it is in gear on the hoist and you turn the wheels by hand you can hear the clunk either in diff or trany,just seems very loose although no grinding when shifting
Old 06-28-2008, 09:43 AM
Yes but the clutch seems fine.there is absolutly no slipping"knock on wood"
Old 06-28-2008, 01:50 PM
just wondering if anyone has had the same issues because summer is short up here and I don't want to take it off the road if it is not going to turn into something major.
Old 06-28-2008, 07:56 PM
RussR's Avatar
more often than not those symptoms are diff related... from my previous experience anyway.
could be CV's otherwise, or even engine/gearbox mounts?
Old 06-29-2008, 02:44 AM
Geary's Avatar
Check the oil for bits. It could be that the spacer separating the spider gear needles has broken, allowing the tiny needles to spill out. The resulting slop could then cause a knock. Other than that, ring gear bolts that have worked their way loose for some reason?
Old 06-29-2008, 10:22 AM
it is something inside the tran/diff for sure.I suppose I would like to know if I can wait untill winter to take it out or will I cause a lot more damage by driving.thanks guys
Old 06-29-2008, 10:23 AM
