you see Arthur...
jasonlee's Avatar
electrical issues
The best of the season to all. Have an issue with a battery drain. New battery in last weekend, no problems at all, starts without hesitation, however today, I shut my car off after arriving home, and nothing. Acessories still work, but not enough juice to crank it. I have had no issues to date. The only differnce it currently because of our weather, I am running my lights and the fan more frequently, but evrything is turned off, when the car is off. Any insight would be appreciated.
Thanks,
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 12-21-2007, 10:20 PM
old man neri's Avatar
Time to bust out the multimeter. I would recommend you start checking to see what kind of drain you have and then go across each fuse to see if you can isolate it.
Old 12-22-2007, 12:08 AM
