Addicted to Racing
edbaus's Avatar
78 turbo 930 performace pressure plate question
Hi,
I have a pressure plate/clutch set up that I bought used.
It is an aluminum setup. The starter ring is in the proper place, everything seems to fit fine, but the inside diameter of the throw out bearing is too small for the turbo guide tube.
I was able to separate the pressure plate into two sections. Looks like it started as a Sachs pressure plate that was machined and a spacer was added.
I do not know who the original mfg is or if I should have a different guide tube or a differnt throw out bearing.
Any help on this is appreciatted.
Ed
Old 12-22-2007, 04:36 PM
