clewett engineering plug wires
I installed the clewett wires today. I am impressed with the build quality, but there is about inch gap between the dust boot on the plug connector and the valve cover. In other words, there is no seal between the connector and the valve cover, is this right?
Can you slide the air seal down?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
yep. slide it down. it is a separate part from the 90 deg rubber portion.
Matt 72 911T Targa - Sold Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat. Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!! |
Thanks, just got it. I never had a set a wires like this.
