-   -   distributor oil (http://forums.pelicanparts.com/porsche-911-technical-forum/38408-distributor-oil.html)
robfix 03-19-2001 11:22 AM
distributor oil
I remember reading that this should be done when you change your cap and rotor. There is a small sponge type thing (technical term!) that I assume is where the lubrication goes. Question is how much to use and what type? Can DC 112 be used here or is their a better application?
Rob Fix
'78 SC Targa
BER 03-19-2001 12:10 PM
Rob,
When you remove your rotor, there is a felt cap in the center of the distributor shaft. I put a couple of drops of "3 in 1" oil on that piece of felt about every 6 months. You could probably use 30 wt. motor oil as well.
Bruce
Bill Verburg 03-19-2001 02:24 PM
Back in the old days you used to get a small gel cap with grease in it. The purpose was to lubricate the rubbing block for the points, thus increasing the service life between point gap adjustments. A little bit goes a long way, you need to keep the contact (the electrical conducting part) surfaces clean.
josh912 03-19-2001 08:13 PM
What a coincidence! I was just about to post the exact same question! http://www.pelicanparts.com/ultimate/smile.gif
Joshua Harrison
1968 912 Coupe
