Options for Front Fender rust repair - 1972
Hello, I have pulled my right finder off and am looking for advice on what to do. I have circled the primary areas of rust (lack of metal), probably more once media blasted. Pictures are of the inner headlight bucket, fender attachment rails, and lower fender rust that had perferated to the both sides.
What are my options?
Thanks.
1972 911t Sportomatic <----- bet your jealous
Old 12-22-2007, 10:57 AM
Evolved
Mo_Gearhead's Avatar
I believe I have seen replacement headlight buckets (not sure of the source).
A good body man can 'cut out' and re-fabricate the missing/rusty sheet metal. But done correctly, that is time consuming ...and thus ...costly!
You might want to look on ebay etc. for a good used fender as opposed to putting a lot of $$ into that one. JMO
Don't fear the reaper.
Old 12-22-2007, 12:04 PM
Jays72T's Avatar
Interested to hear about this since both my buckets are toast.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 12-22-2007, 12:52 PM
It looks like there are headlight buckets here:
http://www.restoration-design.com/
and bottom fender piece here:
http://www.alfaparts.net/911.htm
I can't find the fender attachment piece (at least the one that is attached to the fender).
Old 12-22-2007, 01:08 PM
i think that fender's a parts donor. cut off the turn signal section and weld it onto an easy to find '74 and up fender. hopefully the donor section is decent after bead blasting it clean.
206 637 4071
Old 12-22-2007, 02:14 PM
onboost's Avatar
+ 1 on John Walker's comment!
RGruppe #180
Old 12-28-2007, 08:29 AM
