rear seat delete - just lost an easy 35lbs out back for $120
I am almost finished with my rear seat delete of my 85 carrera...I had already removed the seat backs, so that doesn't count in my 35 lbs. Bought my RSR seat delete from AppBiz...good service, fast shipping.
I weighed each of these and they came out to 39 lbs in total that I removed. ![]() I added back this light weight 4 lbs insulation from Pep boys ($20) ![]() The real pain was cutting this stuff for the seat area.. almost finished putting the carpet and RSR seat delete carpet back. ![]() This is a really easy and cost effective way to lose 35 lbs off your rear...
85 Carrera 2011 Cayenne Turbo |
I have the same carpet kit here, just waiting for the opportunity to install it. 35 lbs seems a worthwhile weight savings, I'm happy to hear that. Especially since no one could ever actually fit in those seats, anyway. I think I can see that you left the seat mounting brackets in place under the carpet? I think this is standard when installing this carpet kit, does it cause any fitment issues or look odd up close? I don't want to have to cut them out if it looks ok.
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
Southern Class & Sass
How hard was it to get the insulation out from under the seats?
Is it possible to reinstall the parcel shelf, and stock carpet, less all the padding? I'm always torn between keeping my car rather stock looking, and shedding some weight for the track.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Yes, i left the mounts in there...i just covered them with my insulation..the center one i may cut around it, or just paint the insulation black so it won't be noticeable...don't see any issues either way.
I think the RSR carpet kit is the way to go though....
here is the finished product....you can also see my homemade car seat clip brackets on the passenger side...
![]() I like the rear seat removal, but I beg to differ on the rear seats It's the factory front seats that cause the problem. With my Sparco Sprint 5 mounted, there is actually a lot of legroom. Sprint 5 saved 20lbs over the stock front seat too.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
You look so comfy in there! LOL!!!!!!!
JP '76 911s Ice Green Metallic bone stock |
i need the male and female leather seat button straps to keep my seats upright....do you have any leftover?
2007 997 TT 1992 500e |
mine were both broken...
