pete-stevers's Avatar
fan belt troubles 80sc
i blew to belts, before i relized the cause...
the fan belt pulley keeper has been badly worn from a rocking pulley half....
can i replace the keeper on the fan side, or does the fan need replacing as well??
Old 12-29-2007, 01:37 PM
I believe you're not getting any replies because your post is, at least to me, incomprehensible. I've never heard the term "pulley keeper," don't know what it is and therefore can't help, although I can assemble and disassemble a 911 fanbelt pulley blindfolded...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-29-2007, 02:20 PM
pardon me steve
i have blown two fan belts before taking the motor out of my 914 with a 3.0sc engine installed
i do not have a cut out in my firewall so i dropped the engine to detail, with intentions of addressing the fanbelt issues as well.....
so....
on observation of the fan belt pulley it was noted the pulley half had been rocking on what i am calling the "pulley keeper"( that is the nut that holds the pulley and fan in place) damaging both the pulley half and the "part"(nut/ pulley keeper) in question
my question is "can the nut be taken off seperately from the fan or is this "part" inseperable, as this "part"(nut/pulley keeper) and the pulley half will both need to be replaced"
that should further muddy the already muddy waters
Old 12-29-2007, 03:14 PM
Okay, so you're saying that some kind of mis-tightening or cross-threading of the big nut boogered up the rearmost half of the fanbelt pulley. What is damaged? The alternator shaft? The shaft threads? The rear half of the pulley? The nut? I'm having a hard time getting a handle on what your problem is, other than that currently, the pulley is "rocking," which I assume means it's turning eccentrically.
Stephan Wilkinson
Old 12-29-2007, 03:23 PM
zotman72's Avatar
Your fan center hub probably has got some ridges developed from the movement of the outer pulley half. A good Porsche shop should be able to take your fan center, weld it up the ridges and remachine the center hub shaft.
The outer pulley half is junk if it is got rounded edges, buy a replacement from our host. Get the right number of shims in there and you are good to go. Make sure you have the circular center washer going the right way too. Search the site for exploded diagrams. I had my fan restored last month by a shop (Eisenbuds) here in Denver for $90. Hope this helps. YMMV
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 12-29-2007, 03:31 PM
Thats it ! the "fan belt center hub"
yes it is badly worn for the rocking of the improperly installed pulley half
i will send away for repair to the place you mentioned
thanks a ton
Old 12-30-2007, 04:46 PM
zotman72's Avatar
Not sure if Eisenbud does out-of-town type work but he might. He is a great crusty, Porsche mechanic. 303 825 0322
He does work on unique scheduling system though.... YMMV
Bill
Old 12-31-2007, 08:55 AM
