1-6-2-4-3-5-1-6-2-4-3-...
1970 911E ignition timing
OK, it's 30BTDC at 6000rpm. What should it be at idle? Or do I not care?
'70 911E Coupe, Webers 40IDA |
You don't really care but I'd say anywhere from 5 ATDC to 10 BTDC.
-Andy
72 Carrera RS replica, Spec 911 racer |
I wouldn't worry about it, and you can't change it anyhow. If you set the timing to some ideal at idle, with the stock distributor you'll most likely be off by quite a bit in the key range of 3000-4500 RPM. I'm pretty sure that they set the timing at 6000 RPM because at that engine speed the distributor is pegged at it's maximum travel, so the springs and such have been removed from the equation.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
