Jaz Jaz is offline
Jaz's Avatar
WUR for 83 911 SC
Hi Guys,
How much would I expect to pay for a used Warm Up regulator for the following: 83 SC engine
63D1215 is a MY'83, 930/10 RoW engine.
9.8:1 cr, 204hp@5900, 189lb-ft@4200,valves 49mm I, 41.5mm E, ports 34mm I, 35mm E, valve timing as on 930/02 C3 engine
Would any of you guys have one for sale?
Regards,
Jaz
http://www.juswant.btinternet.co.uk
Old 01-03-2008, 09:04 AM
ianc's Avatar
If your WUR is acting up, one option to consider is modifying it to make it adjustable. To me this is cheaper and more sure-fire than hunting for an old used one which may not be in spec anyway. After the modification, you can set your cold control pressure exactly where it's supposed to be. Search here for more info on the procedure. HTH,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 01-03-2008, 12:55 PM
