What kind of pliers fasten hose clamps?
I've looked on Snap-on and Craftsman and can't identify the type of pliers used to snug up this type of hose clamp:
In the past I've used end-nippers, but I know that's not optimum. |
Your local plumbing supply store should have what you are looking for. They are the same pliers used for the PEX plumbing hose that is being used in houses now. Take the hose clamp with you to make sure you get the right ones as there are a few different varieties. Expect to pay $150 or so. I have a pair for plumbing projects and they work great.
Don: A quick search shows that to be an Oetiker Hose Clamp.
Here are plier options: http://www.northernbrewer.com/tubing.html They say wire cutters do the trick ($13.50): ![]() Or use the tool specifically designed for the task ($31.99): ![]()
Warren & Ron, may you rest in Peace. |
I have never tried nippers but the plumbing tool has a ratchet and leverage mechanism like bolt cutters do. They install the clamp and it will NEVER come loose :-)
Yep, seems the ratcheting types are what the pros use. Start at $130. Pex looks like a well rated brand.
you can use wire cutters or what are called carpenters pincers... these have sharp edges... the Oetiker official crimpers have "rounded" edges... If you were going to do many of these I would get the "official" tool - the Knipex tool pictured above looks very good... can be used at many different angles.
Schleprock
IMO the ratcheting one isn't really necessary. The small Oetiker clamps don't require gorilla effort to clamp them. I've got the Knipex tool and it works nicely for the DIY hack like me.
Kevin Lehmann '79 911SC-based 930/934.5 FrankenPorsche NASA GTS-3 |
Member
Kent-Moore also makes a GM special tool for these boot clamps, it uses two breaker bars for leverage. Let me know if you want the Kent-Moore part number.
Our shop guys use the flat front dikes.
Paul 91 964 C2 Targa |
Like stated above you need cv boot clamp pliers that' what I use. The pair I have are snap-on tool #YA3080 hope that helps.
Tony Proasi 1969S 1957 VW Pickup |
I have a Snap-On boot tool, it will tighten the band, then with the crimping pliers, you tighten the clamp, with the end-nipper type pliers, while keeping tension on the band with the clamp tool. I have used the end-nipper type pliers to tighten the "factory style" crimped on hose clamps. It is very similar to the one in the first picture, but has a blunt edge instead of a cutting type edge.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
I use these:
![]() I got mine a few years ago locally but I found them online just now for $16. They are made by KD. Google for "KD CV JOINT BOOT CLAMP PLIERS" -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i Coupe http://members.rennlist.org/messinwith911s/ |
Thanks everyone!
Drive's a 911 Every Day
Don!
Simple Hello! Hope all is well! Jason |
