kbruz's Avatar
Cat Converter on Carrera
The bracket that holds the cat converter shield on my car is broken. The bracket is mounted by two bolts to the shield and by two bolts to the interface between converter and exhaust. The two bolts to the exhaust system are in pretty bad shape.
What is the best method to break them loose? I'm guess cut the bolt heads with a dremel and then knock out the bolts with a center punch and hammer?
Also, when I replace the bolts should I replace the gasket between the cat and exhaust?
kb
mercedes GLK350
2009 boxster s
86 targa
Old 05-31-2008, 10:18 PM
Heat is your friend if you have access to it. Mine were in worse condition (couldn't get a wrench on them), so I cut/drilled/cussed them off...a real PITA. Yep on the new gasket.
Old 06-01-2008, 02:38 AM
Wavey's Avatar
You'll find it easier to cut the nuts off, rather than the bolt heads. Bolts are extremely hard, nuts not so much. I used an air chisel.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 06-01-2008, 04:21 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Dremel worked fine for me...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 06-01-2008, 04:23 AM
KatoKato's Avatar
I drove to Midas where a guy I know used an acetylene torch to melt them away. Charged me $20 and it was almost instant...
Stainless bolts, Permatex?, and gaskets...
Old 06-01-2008, 04:29 AM
Diss Member
Quicksilver's Avatar
At the temperature these things see the type of stainless bolts you can find in hardware stores will still corrode. The best 2 additions you can make to this list is copper nuts and a really good antiseize.
Most of the antiseize you can find is aluminum based. It is better then nothing but it really isn't that good. Really good antiseize is copper or nickel based. That will insure you can take it apart later.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-01-2008, 05:38 AM
kbruz's Avatar
I dont have access to heat at home. Once I cut either the bolt head or nut, will the bolt come out or will I need to drill it out?
kb
mercedes GLK350
2009 boxster s
86 targa
Old 06-01-2008, 06:25 AM
Zeke's Avatar
Punch it out and don't worry about that shield. Mine was broken the same way and I tossed it.
Old 06-01-2008, 08:10 AM
3.2 CAB's Avatar
When I had my muffler and other parts off, that 2 eared bracket had one of the ears broken and the actual guard had one of the mounting ear tabs cracked off towards the front of the guard. I mig welded the bracket ear back on and the mounting tab on the guard was also mig welded. Being these parts are stainless steel, that is what I used in my mig. They came out great, and have been there now close to 4yrs. The muffler to cat does need a new gasket. Your old gasket will probably have bits and pieces that won't want to just pull off, you will need a grinder of some type to get a flat sealing area again. The factory gasket # 911 111 191 01 is what is called for, but a quality 2-1/2" header collector gasket will work. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-01-2008, 11:24 AM
3.2 CAB's Avatar
Newest additions-
others...
burgermeister's Avatar
You may find this helpful also:
How do I remove my muffler from the cat?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 06-01-2008, 12:01 PM
kbruz's Avatar
Thanks for all of the feedback. This really throws a wrench in the process for me. I was thinking about just removing the two bolts so that a new bracket could be mounted. But reading the link that burgermeister posted indicates that I'm going to need heat and the plan to punch out the bolts after I grind the heads probably will not work by itself.
I might just see I some one can weld the broken seam.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 06-02-2008, 11:26 AM
Just cut the thing off. Don't drive in tall grass or piles of dead leaves.
Old 06-02-2008, 11:32 AM
What tcar said! I have a euro premuffler (runs cooler than a cat) so it's unnecessary and I don't have one...it's just a heat shield to protect the ground below from burning.
Old 06-02-2008, 03:56 PM
If you drive in inclement weather, the shield also keeps the water / slush off the cat, which probably increases the durability of the steel shell by preventing all that thermal cycling and local quenching caused by every puddle you drive through...
Old 06-03-2008, 02:29 AM
