Pool Janitor
Small Reservoir w/ clear cap at fuel filler?
Since I've had my car I've had to put fuel in it a couple times so far, there is small reservoir next to the fuel filler with a clear plastic lid? The OM says it's for the windshield washer fluid? My car has a washer fluid bottle or reservoir under the hood. Are there two and which one do you fill? My tank under the hood was 1/2 full. I filled it from the access under the fuel lid and all of the contents I poured in came out of a long rubber tube from under the left front wheel-well? I don't get it.
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" < '88 Porsche Carrera Cabriolet Sold > |
That is the reservoir for the headlight washers. You should see two little black teardrop shaped fittings on top of your bumper, they are the spray heads, one in front of each headlight. It sounds like the hose has come off or has deteriorated and is leaking. You should be able to track the hose from the container to those spray heads and replace or repair the tubing. Good luck!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Something's loose in the main reservoir located in the front left fenderwell.
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
The reservoir in the luggage compartment is for the "intensive wash" This operates through the windshield washer jets. The fluid should be the Porsche "silicone remover" fluid part number 928 628 931 00.
The headlight washer fluid is in the main windshield washer reservoir.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
