-   -   Gasket Material Needed (http://forums.pelicanparts.com/porsche-911-technical-forum/385547-gasket-material-needed.html)
scottb 01-04-2008 12:06 PM
I need some very thin gasket material. .010 or .005 preferably. It's for a fuel shut-off valve, so it needs to be fuel resistant and able to withstand the valve "ball" rotating against it. Paper material won't work.
Suggestions would be appreciated. Sources for purchasing a relatively small amount would be appreciated too.
Thanks.
Scott
cgarr 01-04-2008 12:14 PM
Might try a pure alum shim stock like this one 9536K14 from http://www.mcmaster.com/
scottb 01-04-2008 12:22 PM
Interesting idea. I'd never considered aluminum as a gasket material.
Thanks!
pozee 01-04-2008 06:38 PM
How about copper?
You're not going to be flying around with an experimental gasket in your fuel valve are you? :-)
sballard 01-05-2008 07:26 AM
A friend of mine who does a lot of work on vintage motorcycles makes thin aluminum shims from aluminum drink cans.
