| MFAFF |
01-07-2008 12:44 AM |
Interesting stuff guys..
I guess I'm quite lucky in that my 'normal' 911 use allows about 5-10 minutes at low speed/ low throttle openings at either end of the trip to get engine temps up or stabilised before putting the car away...
I don't feel its necessary to blip the throttle before shutting it off...never have done so with fuel injected cars....and the carb ones I have driven were rentals :).
Shutting down the turbo car (Audi S2) is a bit more painful.. it needs a couple of minutes at idle to bring the turbo to idle speed...and cool down a bit. So by the time I have stopped, radio off, unbuckled, gathered my stuff together that time has elapsed and so it can be shut off.. There is a specific cooling circuit on the car to cool the turbo down further, separate from the main cooling system and you can hear it kick in if you shut off too soon..sadly there is not a similar oil system. Cooking the turbo bearings is easily done and a full refurb is expensive and but at 125K miles not unexpected..
Similarly 'calm' use of the throttle until there is some heat in the system is adviseable...usually guided by the water temp guage and oil pressure guage.. the pressure drops as the engine heats up...
