Addicted to Racing
edbaus's Avatar
Rear brake sugestions for a 930
Hi,
I have a 79 930. The original calipers are gone. The front axle has 993 front calipers with adapters, the rear has nothing.
I was thinking that I would be able to use one of the variants of 944T/964/993 calipers to fit to the rear, but I did my size calculations last night, and it looks like the only way I can make an adapter fit is if I weld it in place because of the position of the mounting face to the centerline of the rotor.
So, what are my options.
I have seen the GTP brembo kit going for $1800,
I can go find some 930 rear calipers for around $600 (which I would want to match with front 930's) But, I do like the look of the later caliper better.
Is there a third option. Is there a brembo caliper out there (rears off an evo?) or something that I can build an adapter for that will work.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 01-06-2008, 04:52 AM
