Any suggestions on removing adhesive residue left from wheel weights. That will not damage the wheel surface.
3m adhesive remover.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Registered Abuser
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
A lot of solvents will do this. Try a test spot. Paint thinner is weak. Those containing acetone and or toluene work better. Then there's the ones with benzene. Be careful with any of it.
And, all this depends on the "wheel surface." What do you have? |
WD40 and rubbing with your fingers. Found out that WD40 is less aggressive than other solvents and removers.
yes! i lean the wheel in such a way that a small pool of WD40 will sit/pool over the adhesive pad. let it sit overnight. add some more if it needs it. then the next day, i use a plastic spatula that people use to smear up spackle, and scrap it off.
poof! gone |
3M. Glue comes right off. No damage to the rims.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
