-   -   Clutch Operated Microswitch? (http://forums.pelicanparts.com/porsche-911-technical-forum/38578-clutch-operated-microswitch.html)
MBradbury 03-24-2001 05:38 PM
Hi,
Just finishing off replacing the pedal bushes on my 83 SC and while I was down there I noticed something that has got me scratching my head! There appears to be a microswitch which is activated or deactivated when the clutch pedal is depressed. What's it for? At first I thought it was the brake light switch but I can't see how operating the clutch is related to the brake.
911 SC Coupe
Nickshu 03-24-2001 05:53 PM
This is the switch for the cruise control which switches the cruise off when you step on the clutch. The same happens when you step on the brake, but this is connected thru the brake light switch on the master cylinder.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
MBradbury 03-24-2001 09:44 PM
Thanks Nick. I must try the cruise control someday.
