Gage surround material gaps - how to fix?
How do you fix these gaps outlined in the green in the picture below. I thought maybe the gage just needed shifted around a bit, but they seem to be where they want to be. Just about all of the areas around my gages are like this to some degree:
Shane - 1984 928S |
Sharpie?
![]() Shane, I'm guessing since you have a cab with the top down a lot, the vinyl facing has shrunk.
Tru6 Restoration & Design |
yep, that is what it looks like, but wanted to make sure that was the case before I decided it would have to eventually be recovered. Is that going to be the only option? I hate to say it, but I was starting to consider a gage surround of some sort.
Shane - 1984 928S |
two words my friend.
leather boots. ![]() you should be able to pull your steering wheel off and gauges out and glue in a new facing.
![]() Just remember that when we start voting for goofiest thread of 2007 please.
Shane - 1984 928S |
Hi, I know exactly what you are talking about. It IS due to weather/age shrinkage of the cover material. You have 2 or 3 options:
1. You can pull the gauges, and sort of massage the rubber trim rings, so they will cover better. 2. You can replace the dash gauge cover facing material 3. Get a fine point Sharpie, and just color in the exposed material that is around the gauges. I have seen all 3 different choices done, and they all look just like they should. Whichever way you go, you should have satisfactory results. Good luck!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
OK, tears are running down my face!!!!!!!!!! I had forgotten all about that thread.
David 1969T (slowly becoming a RSR clone) 1984 944 (hurtin' bad )1990 BMW 325iC (fun sunshine car) |
Shane - 1984 928S |
RETIRED
Pull all the gauges and simply recover the dash. You can also try Madera Concepts, they do dash faces for the whole interior. Rosewood veneer, Carbon Fiber, etc....high class stuff. They do restorations for vintage Jaguars, Bentley, Aston Martin etc....
They are local to me in Santa Barbara County and should be on the web.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
That's right. Didn't you just do a CF gage surround on one of your's Mike?
Shane - 1984 928S |
RETIRED
Didn't just do it....the gauge backing has been like that for quite awhile. Probably about 5+ years in a cabriolet that usually has the top down and full sun being on the west coast. It's held up pretty well.
But everyone noticed the CF when I posted pics in the thread with the new 964 gauges in my SC.....
I'm ready for the drive. Always look forward to that! So we may have a Ferrari with us. I guess we can slum a little . He should stand out!! It would be great to have Scott with us but you are right. Danged Bimmer would fly before, can't imagine now.We need to get Rarly to come up from Huntsville. No further than the Memphis guys would drive. OK, back on thread...........magic marker
