Top Dead Center sensor
Where does this thing go and what does it "read"? The part diagram is not that clear.
http://www.pelicanparts.com/catalog/.../1-1-10-53.jpg |
As far as I know on a 3.2, the TDC sensor is only used for diagnostic testing, not an engine running requirement, other engines may vary.
+1. That is a bracket for the TDC sensor that is only used for diagnostic purposes. The sensor fits in the bracket and then a wire leads to the back of the engine where the plug for the sensor is capped off with a little yellow cap. It is bolted up near the idle stabilizer valve.
OK, good to know. Thanks!
Does anyone know what the 3 pins in this plug are for?
I assume gnd, signal from TDC diag sensor, but what's the 3rd? I actually have to use this TDC sensor for some timing calculations I'm making for another crazy project. Thanks. |
Shield.
So the 3 pins all are basically used for the TDC Diag Sensor only? Meaning the wire harness ONLY goes between the Diag sensor and the connector with the 3 pins? So the sensor has 2 outputs ('+' & '-') and a shield? Sorry for the dumb questions but it's a pain to trace in the engine bay. Thanks. |
Sal
Yes and Yes. |
