Any tips on tightening 84 Cabriolet drivers side window.
Hello,
I would like to tackle tightening my drivers side window on my 84 Cab. Rattles and is loose. Any tips or tech info once I open the door panel. Is the window glued in place or mechanically fastened? Thank you, John Mitchell Big island Hawaii |
Hi John, that is a very good question. It is too bad that I don't remember which way it is. I have not had my door panels off for 5 or 6yrs, and I just can't remember. I am thinking that they were actually a compression fit in the bottom window regulator channel. I don't remember having to remove any through bolts at the bottom track. I may be incorrect, but I don't think that they are bolted into the bottom channel. Good luck!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Subscribe. I have the same problem with my '86 Targa.
1986 Targa 1968 MGB (2) |
Monkey Butt Forespin
My driver's glass actually fell out of the channel last year in my 84 Cab. Rather than convert to the cross-arm regulator (& the work associated with it), I used some silicone sealant to plant the glass in the channel. Knock on wood, has held for a year now...
I believe our host has (had) some diagrams showing it.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Thanks guy's, I appreciate the info. I will have time later this month to remove the door panel. Will post what I learn.
Thank you, John |
