dickster's Avatar
progress - t/bars and bushes install
ok finally took the plunge and started unbolting everything. toms got a great write up on his website that i am not attempting to repeat, just wanted to post my experiences - its not a very technical write up!
first the left rear bar. notice that although wood is not ideal for jack stand pads, i do have the rear wheel under there for insurance!
first problem was removing the wheel which i posted about in another thread.
2nd was removing the rubber rocker panel trim strip. having failed for about 15 mins to figure it out, i got the bently manual out!
it just pulled off, leaving the screws exposed to enable removal of the rocker panels.
i thought it would be a pita to remove the caliper and disk so next i removed the shock bottom bolt, with the jack supporting the hub.
then with jack still taking the weight i removed all the radius arm to banana arm bolts/nuts. also time to remove the t/bar cover plate bolt/spacer (bottom right out of view) that normally would take the strain of an unsupported radius arm.
with the jack lowered i unbolted the t/bar cover plate and removed it.
removed from the car it is obvious how worn the bushes are.
now the t/bar is exposed (it looks new!).
it took alot of wriggling to remove it but finally it moved.
here it is compared with the replacement.
and thats it. alot more straight forward than i thought. i didnt have to move the caliper/disk. removal took 1 1/2 hours because of said problems (not reading manual) - should be done in an hour on the other side. next job to remove old bushes and reassemble.
cheers.
Rich
'86 coupe
"there you are"
Old 11-23-2003, 06:32 AM
Binge User
Schrup's Avatar
I'm right behind you, I already have removed, cleaned, & sand blasted my entire front suspension. Hope I can remember how it goes back together. I started the rear last night, but opted to hold up & read the Bentley before proceeding. It's a bit more involved than the front. I plan to take off the banana arms & CV joints, & found I needed a 29mm socket for the rear hub that I didn't have. I need to take some pics to post. Good luck & keep us posted.
Paul
Old 11-23-2003, 06:53 AM
Craig Roche's Avatar
I'm also redoing the rear suspension! I admire your self control! I started to do some undercarriage detail then decided to redo the suspension. Then I thought I'd better fix the oil leak at the tank so I took it all the way out!! I've had thoughts of taking the engine out :-) Where does it stop? I keep thinking, while I'm here I should.....
BTW what bushings are you going use on your spring plates? Great action photos! Thanks
Craig
1984 911 Targa
Old 11-23-2003, 08:36 AM
Chuck Moreland's Avatar
Great progress! You'll want to paint those new tbars, then coat with grease to prevent corrosion.
Keep us posted.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-23-2003, 09:38 AM
dickster's Avatar
i am a strictly in and out guy! none of this cleaning everything up and painting nonsense!
chuck, are you serious about painting the bars? what paint? i was gonna just coat in grease, isnt that enough?
cheers for the comments guys, and good luck with yours!
Rich
'86 coupe
"there you are"
Old 11-23-2003, 09:49 AM
Yes, I'm serious about painting. Any good enamel should be fine, be sure to clean them first for good adhesion.
Old 11-23-2003, 10:02 AM
dickster's Avatar
chuck,
thanks, i'll get some.
Rich
'86 coupe
"there you are"
Old 11-23-2003, 10:37 AM
Chuck, I don't mean to disagree with you ('cause you know a heck of a lot more about these things than I EVER will), but when I mentioned putting a coat of POR-15 on my torsion bars, Steve Weiner talked me out of it (and I realize that some bars come painted). Steve said (and I'm paraphrasing here) that since the bars 'twist', the outside layer of paint would not necessarily remain intact. I therefore simply put a good coat of grease on mine (Sanders t-bars), and installed. I will say that both the front and rear t-bar tubes looked 'like new' inside (as did the original bars), so I'm not at all worried about moisture, corrosion, etc. in my car. I just wanted to throw this info out here for discussion (I'm sure the paint wouldn't hurt anything, but does it help)...
ps. Chuck's (Elephant Racing) poly/bronze control arm & spring plate bearings are extremely nice...HIGHLY recommended from my perspective!
Old 11-23-2003, 10:51 AM
dickster's Avatar
keith,
what did occur to me (and i value chucks opinion ) was that if paint did come off it would leave the surface unprotected, but if it was all greased to start with...........
Rich
'86 coupe
"there you are"
Old 11-23-2003, 11:19 AM
dickster's Avatar
craig,
sorry, forgot to say, i'm gonna use neatrix.
Rich
'86 coupe
"there you are"
Old 11-23-2003, 11:22 AM
I see reasonable arguments for both approaches.
However, paint will flex some without breaking off. The factory bars come painted, and so do all aftermarket bars - except Sander.
The coat of grease encapsulates the paint and will protect against any micro cracks that might develop. I can't imagine a quality paint properly applied flaking off in big chunks.
I have handled used Sander bars that had been painted. They showed no evidence of paint flaking, cracking or rust.
Lastly, its pretty hard to install them without scraping off some of the grease as the bar slides through the torsion tube hole. I like to know there is a coat of paint anyplace the grease is wiped away.
YMMV.
Keith, glad the bearings are working out for you.
Old 11-23-2003, 11:41 AM
dickster's Avatar
i have to say that on the bar that came out the black paint is unbroken - it looks new.
Rich
'86 coupe
"there you are"
Old 11-23-2003, 11:49 AM
Binge User
Schrup's Avatar
Here are my front strut mounts, pretty ugly,but still gonna use them.
removed A/C & cruise control
now all I need to do is bach date my heater.
Paul
Old 11-23-2003, 02:11 PM
dickster's Avatar
and so it continues...............
first job was to remove the old bushes and clean up the springplates, it took about 1 1/2 hours with a blowtorch and i went through two wire brushes - not much fun there!:
next loosen clamp and adjuster and recentre the ride height adjustment:
then used my fav. lube to install new bushes, there thats much better:
Rich
'86 coupe
"there you are"
Old 11-29-2003, 03:03 AM
dickster's Avatar
then in went the well greased new t/bar:
check angle of car front to rear - mine was 1.5 degrees:
as i wanted to shoot for 24" ride height according to will's calculator i needed 17 degrees spring plate angle. take the 1.5 away from that and i needed to install the spring plate at 15.5 degrees - got it first shot!:
Rich
'86 coupe
"there you are"
Old 11-29-2003, 03:08 AM
dickster's Avatar
the cover was installed next and was a pita. with the new bushes it required a fair amount of brute force (helped by a carefully applied club hammer), and fiddling to get it on and the bolt holes lined up (i think others have used longer bolts to get it on initially):
then with the help of a jack bolt the spring plate to the banana arm:
a bit more use of the jack to get the shock bolt in:
Rich
'86 coupe
"there you are"
Old 11-29-2003, 03:15 AM
dickster's Avatar
wheel goes back on and then the best moment, dropping the car for the first time:
looks good. got to within less than 1/4 inch of 24" - not bad! and i guess it will move towards 24" when i do the other side. thanks will:
i love the look of the lower ride height, especially with 15" wheels, and i am tempted to leave the rockers off!!!
so one corner down, three to go. i didnt paint the t/bar on the advice of my supplier. also i just found out i got hollow bars - i didnt realise!!!
Rich
'86 coupe
"there you are"
Old 11-29-2003, 03:21 AM
Glasgow 911SC's Avatar
Richard
So did you just remove one spring plate at a time? If so, will this affect the ride height once both are done? Is the place you put your jackstands in the pics above the best way to do it? I'm guessing the wheel was still on the other side make it quite stable.
I'm trying to get as much info as possible before I go through this myself.
Oh, and where did you end up getting the angle finder thingy?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 11-29-2003, 04:36 AM
.....and when are those 930 brakes getting bolted up?
Chris
Old 11-29-2003, 04:46 AM
AirCooledExcellence's Avatar
Nice work Richard!!
Well done for taking pics on the way!
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 11-29-2003, 05:25 AM
