powder coat Muffler
I have a nice Dansk mild steel muffler that i Blasted clean with media. I would like to paint it gray or satin Black. I have heard of using BBQ paint and other high temp paints but would really like to have the durability of Powder coat. I called my powder coater and they said they don't have a high temp paint.
How hot does the muffler get? Has anyone powder coated a muffler in the past?
O22$pa
70 porsche 911t
52 mgtd
Old 01-07-2008, 12:02 PM
gshiwota's Avatar
Don't do it. Powder coating will not hold up on a muffler. There are special powder coatings that can withstand the high temp environment, but typical job-shop coaters won't spray it because it takes special equipment. Standard powder coatings will turn to ash under high heat.
I was a powder coater for 7 years and powder coated the muffler on my 356. It looked great for about 2 hours before the coating started to ash off.
The best thing for mufflers and headers is to JetHot coat. It's great looking but this is expensive stuff.
In my experience the best low cost professional coating for mild steel is to have the exhaust aluminized. This is a process where they spray on a molten aluminium coating to the part. The finish is a really rough aluminium color (think, tin-foil + stucco). This holds up well to very high heat and maintains it's color well. I ended up aluminizing my 356 exhaust and it's held up very well for the past decade.
Gabe
Old 01-07-2008, 12:09 PM
gshiwota's Avatar
I guess I didn't really answer your other questions... typical powder coatings are good to about 400 degrees F. Exhausts can get to 700+ degrees - Porsche exhausts get really hot since they are so close to the motor.
BBQ spray paint should also work but it won't stop rust like aluminizing. I'd aluminize that muffler and spray paint over it (if you want a dark color) and you shouldn't have to worry about the spray paint flaking off or the muffler rusting from the outside.
Old 01-07-2008, 12:13 PM
Thanks for the advice
Im in San Clemente,
Any local locations to have this done?
O22$pa
70 porsche 911t
52 mgtd
Old 01-07-2008, 12:19 PM
I've been running powder-coated HEs and a factory muffler for the past 10 years, before ceramic coatings were an economical option. The HE's and muffler are still good. The exhaust system is probably rusting faster from the inside out. I think there are heat-resistant PC materials for this application.
Pyramid Coatings in Sun Valley (So. Ca.) did mine way back. A key to this procedure is to have scrupulously clean base metal. Compare prices with ceramic coating. Today, I would recommend that process over powder-coating. Ceramic coating can be applied to the inside as well, but it's gotta be clean.
Sherwood
Old 01-07-2008, 12:45 PM
jhubs's Avatar
The BBQ paint does not work either...ask me how I know
Jerry
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 01-07-2008, 12:49 PM
AutoBahned
RWebb's Avatar
check out the stuff that Eastwood makes - it 'rubs in'
Old 01-07-2008, 01:46 PM
19 years and 17k posts...
azasadny's Avatar
I painted my stock muffler with Wuerth hi-temp paint from Pelican almost 2 years ago and it still looks perfect, no flaking, peeling or bubbling...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 01-07-2008, 02:20 PM
Pete000's Avatar
Any shops in LA CA do the ceramic coating or the Jet Hot ?
Work to Live, don't live to work...
Old 01-07-2008, 02:23 PM
rfuerst911sc's Avatar
Don't limit your search for just Jet Hot as that is a " brand " of coating but not the only one. I did a search here in Orlando for " ceramic coating " and found a local vendor. He told me that all the vendors out there including Jet Hot buy their ceramic material from one manufacturer in California. My local guy coats mufflers for $70.00.
Old 01-07-2008, 02:59 PM
esample's Avatar
I only did mine a few months ago, but same results so far. Used Wuerth's also. Anything more would be a waste of $$ for me. YMMV.
-e.
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 01-07-2008, 04:52 PM
I'd go with the "jet hot" but have never used it. I bought a few spray cans of VHT paint (very hot temperature) and bead blasted the exhaust cross over pipe and headers and then used the spray paint according to the instructions. These meant curing the paint in the kitchen oven (which meant evacuating the house because of the smell). The piant still looks great after 2.5 years. I also painted the cat bypass but didn't bead blast it and some paint has flacked off. I may get it chrome plated at a buddies shop this time for grins. From what I've read the "jet hot" coatings hold up well and while the paint has held up well the price difference between paint and "jet hot" at $70 is worth it.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 01-07-2008, 04:54 PM
jtkkz's Avatar
We have the new powder coat in 1000 degrees in black.. I had my muffler in my car now for about 2000 miles... so far so good...
www.sycipdesigns.com
Ceramic coating is still the best....
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 01-07-2008, 08:21 PM
Insane Dutchman
I painted my muffler with Wurth Zinc paint....it has been only 14 years so I am not sure about the long term, but so far it still looks like the day I painted it. If you don't mind flat battlship grey it should be ok...
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 01-07-2008, 08:52 PM
Regis turd ab user
Eastwood high temp coating, 1,200' spray or foam brush application.
Stainless grey for early cars (mine) and I have used black as well.
Good product
Old 01-07-2008, 09:05 PM
gshiwota's Avatar
Just spoke to my brother who runs the powder coating shop I used to work at and he recommends Zinc Nation in Anaheim for metalizing. He refers customers to this shop and says he has had very good feedback from customers he refers there.
Here's their info. www.zincnation.com
Gabe
Old 01-07-2008, 09:30 PM
3.4 Bigger is better
88-diamondblue's Avatar
I used VHT high temp paint on my exhaust. I used clear which turns a bronze color after it get very hot but has not flaked off and has not been affected by anything. These have been done in clear and were baked according to VHT instructions.
You can see how the clear coat bronzed after baking and has gotten slightly darker with use.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 01-07-2008, 09:54 PM
Regis turd ab user
Michael, nice results!
Is that clear over stainless?
Old 01-07-2008, 09:59 PM
Yes it is. The muffler has darkened a little more than I wanted but the HE's have stayed just about like the picture after 8000 miles.
Michael
2020 Honda Passport
Old 01-07-2008, 10:49 PM
Try this web sight. They have high temp coatings that can be applied and air dried or baked.
www.caswellplating.com
Old 01-09-2008, 07:07 AM
