Wiring window switches
Evening everyone I put on a new door stop this evening and am trying to get the wires connected back up to the switches. I must have the passenger side messed up as it won't go up. It will go down. I have done a few searches and found good information, (like if the drivers side isn't working properly the passenger won't either, which is the case). And I have a Bentley manual.
THe answer I can't find is this. I know the terminals are numbered and were the colors go, what I don't know is which terminal is 1, 2 etc. etc. The manual shows 5 being on top down to 1 but is 2 the right or the left. It's tigher than a tick in a teddybear in there and I can't see if there are even any numbers on the switch itself. Anyway, thanks in advance.
O2 In Sully We Believe
Old 01-07-2008, 07:16 PM
carreradpt's Avatar
Mark, I have a couple of diagrams that I kept handy for this very thing. For the pass door, my diagram shows 5 points. Top row; red/wh and brown; next row blu and blu/blk, and the bottom one is red/blk. The drivers door pass switch is; double red and brn; red/wh and red/blk, and the bottom is double red and one of the wires is squiggly (my car).
I think I was reading these as I look over the switch when it is pulled out.
If you need I can pull one and take a peek.
Hope this helps. DT
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 01-07-2008, 08:46 PM
Dan, thanks for the reply, the manual says, (for my 84'), red/white 3, black 1, brown 4, green 2, and red/black 5 with 5 being on top. My switch is 1 on top, 2 middle, and 2 bottom. Again, I just don't know what numbers correspond to the actual connectors.
Old 01-07-2008, 08:53 PM
I was just looking at the manual, our cars should be wired the same. They do show two schematics one for 84' & one for 85' but for the passenger window switch wiring is the same, (maybe my switch is upside down).
Old 01-07-2008, 08:57 PM
carreradpt's Avatar
Mark, I found a spare switch. Here you go. With the 2 prongs on top and you facing the prongs, 5 on top left and 4 top right. Next 2 and 1 and 3 on bottom.
Dan T
'85 Carrera
Old 01-07-2008, 09:11 PM
Good morning Dan, again thank you for looking into this. But my switch is 1 top, two middle, and 2 on the bottom. I'm going to pull the switch and see if it's numbered.
Old 01-08-2008, 04:19 AM
Got the switch out & with a magnifying glass I can see the terminals are numbered. I'll take a picture of it later and mark the numbers fro anyone else that may have this problem, again thanks Dan
Old 01-08-2008, 04:47 AM
3.2 CAB's Avatar
Just confirming that the switch pins are numbered. It would have been so easy if they had used connector blocks like almost all other manufacturers do. I have been down that road when I had to find out why the windows weren't operating correctly. I think that I made an enlarged schematic of the switches and wiring at the time. Good luck!!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-08-2008, 06:13 AM
Happiest when Tinkering
gsmith660's Avatar
look at the sc wiring diagram here on pelican the switch layout has not changed in years and should help you visualize the hookup.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-08-2008, 08:32 AM
ok gotter done Thanks to all. I did encounter another problem. After writing down the numbers from the switch on a piece of paper and writing the corresponding colored wires I went down stairs got it all hooked up and the window went up pushing down and visa versa. Thought I had the switch upside down, redid, and didn't work at all. Came back up and re-read a thread Johnny Walker had commented on a few months ago that the two middles wires actually run the motors. I took the switch back out and put it in the original way with one terminal on top. I reversed those wires and presto, Correctly working windows!!!!
So my point to all this... I believe my Bentley manual is wrong. The scamatic shows the red/white wire going to #1 and the red/black going to #2. The window works backwards with the wires that way.
Anyway just an FWI
Old 01-08-2008, 12:23 PM
Throw it on the ground!
Anyway just an FWI
Now go look over on Rennlist and search for lighted BMW light switches and do 'em all over again!
http://forums.rennlist.com/rennforums/showthread.php?t=334167&highlight=bmw+lighted+switches
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 01-08-2008, 12:40 PM
REAL nice Mark!!!!!!!!!!!!!!!!! Man, what are friends for!!!
Old 01-08-2008, 02:47 PM
3.2 CAB's Avatar
Yes, those appear to be the same window switches as in my 750iL. I saw his mod on this, looked really nice!
Newest additions-
others...
Old 01-08-2008, 06:17 PM
