-   -   Another IROC build - Aussie RHD 3.8 (http://forums.pelicanparts.com/porsche-911-technical-forum/386357-another-iroc-build-aussie-rhd-3-8-a.html)
matty74 02-08-2009 12:14 PM
Craig,
With your floor boards, you should consider rennline, I have them in black it would finish of that part of the car nicley.
Matt
EarlySport 02-09-2009 08:42 PM
Originally Posted by TunersGroup (Post 4472607)
Great thread EarlySport. I'm in Sydney too. Are you a NSW Porsche Club member ?
- Adam
Hey Adam,
Yes, I'm a Sydney sider, and a PCNSW member. Have never been to a club meeting unfortunately though - time is always too tight!
When this car is completed I'm hoping to do some club runs.
Cheers,
EarlySport 02-09-2009 08:43 PM
Originally Posted by matty74 (Post 4472743)
Craig,
Matt
Hey Matt,
Did you end up picking up the 3.6 for your car?
rs27carrera 02-10-2009 03:24 AM
Graig,
Do you recall what was make and where did you buy that special muffler?
I do have one 930 in Sydney and I am in process to modify original muffler and idea came just to use muffler like you have; in/out in one end and then just to have 180deg. elbow in opposite end.
Regards, Harri
PS. My car is going to have 3.0RS look too, rear wing will be just Carrera / early turbo wing where I have made space for intercooler. Will post some pics once I manage to get more parts ready.
ninesixfour 02-10-2009 04:08 AM
Looking great. How about another pic of that exhaust from the other side?
TunersGroup 03-01-2009 05:53 AM
Originally Posted by EarlySport (Post 4414168)
You'll also note the steering wheel quick release for the Prototipo.
http://forums.pelicanparts.com/uploa...1231824221.jpg
What brand of quick release is that ? Is it a ball lock quick release or a pin system ?
- Adam
wachuko 05-01-2009 02:35 PM
Any updates?
EarlySport 05-31-2009 08:43 PM
Time for some more updates!
Firstly, their is the one-off custom plexi rear quarter windows. The goal here was a much flusher fit to the body, extreme light weight, and an inconspicuous look. The material is 3mm thick for lightweight, and uses a lightweight plywood frame to hold it in place.
Here is the ply frame ( painted black ) and the plexi cut from templates.
http://forums.pelicanparts.com/uploa...1243827160.jpg
Here is the frame in place - it mounts through about half a dozen screws drilled through the window frame. The resulting gap between body and ply frame is filled with a low tack silicon sealant to ensure the window is weatherproof.
http://forums.pelicanparts.com/uploa...1243827280.jpg
http://forums.pelicanparts.com/uploa...1243827317.jpg
Note in the previous pic the edge of the plexi window on the inside was painted black to hide the glued area. Now the window is glued in place to the frame - again with a glazing silicon.
http://forums.pelicanparts.com/uploa...1243827397.jpg
And the outer plexi mask removed.
http://forums.pelicanparts.com/uploa...1243827443.jpg
The inside of the ply frame provided a glue point for the suede headliner. Suede also wraps the B pillar and lower section of the window frame, to neatly finish the interior trim to the window. You can also see below the suede headliner, which is a single piece of suede front to back. Not difficult in a sunroof car as the headliner trims up to the sunroof opening. The key is to get it tight and even, as suede has very little stretch.
http://forums.pelicanparts.com/uploa...1243827542.jpg
Lastly the inside masking is removed ( when the glue has dried ) and the side windows are complete.
http://forums.pelicanparts.com/uploa...1243827682.jpg
You may have also noted the 3mm plexi rear screen too. This is installed using an OEM window seal, although some cuts and re-seal were required in the corners due to the material being thinner than stock. Making the plexi a touch larger than the OEM glass naturally pushed it into a very stock looking curve when installed. More pics later..
Then it was onto the interior trim...
EarlySport 05-31-2009 08:58 PM
I spent some time playing with one of the Appbiz carpet sets that we sell, but ended up wanting a more integrated appearance in car. That meant using unbacked (stretchy) carpet to trim the area around the rear seats. This was also used for the side area under the windows, with a backing at the top to provide some shape. The carpet is a black plush style, and very lightweight.
Prior to trimming in carpet, a small amount of dynamat style material was used to seal up any gaps in the OEM sound pad. This is an effort to quieten the car down without adding significant weight. Removing the sound pad itself would reduce weight, but at this point I'm happy to compromise a little to ensure the car is pleasant on the road.
http://forums.pelicanparts.com/uploa...1243828182.jpg
The carpet is installed with some pre-stretching done. Cuts had to be made at the rear seat bottoms, which will be covered by custom pieces.
http://forums.pelicanparts.com/uploa...1243828255.jpg
The rest of the carpet is glued in place. Trimming this rear seat area alone was about a 4 hour job.. Some of the carpet kit is also used - the rear deck piece, front footwells and mats will be used. The custom centre console ( for the raised shifter etc ) is trimmed in matching black carpet too. Where applicable ( the sill panels for example ) a backed carpet is used for more durability.
http://forums.pelicanparts.com/uploa...1243828411.jpg
http://forums.pelicanparts.com/uploa...1243828450.jpg
http://forums.pelicanparts.com/uploa...1243828481.jpg
There is still a short list of things to do - front grille mesh, custom carbon removeable sunroof insert, carbon rear reflector piece, and suspension ride height setup and alignment. We are getting close however! Here's a teaser of the car on it's wheels..
http://forums.pelicanparts.com/uploa...1243828657.jpg
More to come next week..
saintz 05-31-2009 09:06 PM
tell me more about the carpet sets you sell. I need the front mats.
matty74 05-31-2009 09:50 PM
me too I want the RS rear seat delete carpet set
geoz 05-31-2009 10:12 PM
sub'd
great job, hoping to seeing it on the road
EarlySport 06-16-2009 10:33 PM
Just a couple of quick shots as work continues..
The Pole Positions are in place, complete with their backs painted in Mexico Blue.
http://forums.pelicanparts.com/uploa...1245216495.jpg
And torsion bars have been re-indexed and ride height set. The car will go for a full alignment and corner balancing when complete.
http://forums.pelicanparts.com/uploa...1245216550.jpg
Door trims are now in place, and wiring has been completed save the stereo. Not sure where speakers are going yet - somewhere in the kick panel / footwell area. The current project is the carbon rear reflector and sunroof insert. The next update - hopefully a week and a half at worst, will be the car finished :-)
To answer some previous questions - the muffler is a generic piece from a Sydney shop, and there are further pics of it's install back in the thread. The steering quick release is a ball type, and for enquiries regarding supply of carpet sets and parts in australia - check the website www.911parts.com.au
dimps8 06-17-2009 03:36 AM
Nice work Craig. Gotta love blue longhoods!
stevemfr 06-17-2009 04:45 AM
Nice!
I know it's a little late now, but I did the center dash vent update on my car too and have a word of warning: I had the dashpad trimmed almost exactly like yours only with leather rather than alcantara (did this 10 years ago - pre alcantara. Like yours, tho.) and after a year or 2 of hot sunshine on the dash, the upper cut of the opening bowed so I now have like 1/2" between the vent and the dashpad in the middle of the vent. Looks sort of crappy and I was thinking I'd try to remove the leather around the vent and glue a 'frame' of thin sheet metal or possibly plastic between the dashpad and the leather to keep the opening rectangular. What are you doing to hang the vent in place? Mine is attached behind the dash with a small bracket (easier than fabricating holders for the original hooks and clips).
Bill Verburg 06-17-2009 05:24 AM
Love the painted seat backs! What sidemounts are you using?
Dave27S 06-17-2009 05:54 AM
Subscribed!
MrPerkles 06-17-2009 06:08 AM
Nice car ive been following this thread,please tell me you are putting longer studs on the wheels ?
wachuko 06-17-2009 07:22 AM
... Then I had the dash trimmed in black alcantara, complete with a french seam around the instrument cluster, done in matching mexico blue thread.
http://forums.pelicanparts.com/uploa...1231824163.jpg
Love that idea. I want to do something similar, but in Orange, to mine.
Looking great! Keep the photos coming.
Is it moving on its own power now?
EarlySport 06-17-2009 08:53 PM
Originally Posted by stevemfr (Post 4726916)
Nice!
Thanks for the feedback - I'm pretty sure my vent opening is framed at the top with a wire that is integral to the dash - I took very little off the top of the smaller factory opening - most of my enlarging was done at the lower edge of the hole. I'm hoping I don't have any similar warping issues. I've attached the vent via a bracket on the back too. This vent will mate up with the fresh air intake at the rear of the hood.
EarlySport 06-17-2009 08:57 PM
Their is already in place longer studs to account for the 1" wheel spacers. There is plenty of thread engagement in the nuts - see the pic below with spacers in place. The blue nuts I am using, while they have an open end, are the same length as OEM nuts ( actually about 3mm longer ), so hence you don't see thread coming through the end..
http://forums.pelicanparts.com/uploa...1245297453.jpg
EarlySport 06-17-2009 09:03 PM
I'm pretty sure they're a Sparco side mount. I'm running the outer ones 'flipped' so the seats are as far toward the centre of the car as possible ( maintaining clearance between the two seats ). A bit less pedal offset that way :-) I've had the side mounts and matching sliders for a while - with the outside mounts flipped they line up with the factory seat mounts and only required drilling some new holes to meet up with the OEM captive nuts.
mondo74 06-17-2009 09:18 PM
where's my receipt?!
haha. nice work craig.
ray
Bill Verburg 06-18-2009 06:55 AM
Yes, I noticed the flipped sill side mount, the only others I've seen like that are the original Cup seats. I guess that the PP's must be narrow enough to do that
EarlySport 06-18-2009 05:07 PM
I have a pair of Momo '1000lakes' seats in an RS Replica that are also mounted the same way, although I needed a welded frame to fit them (see pic below) The outer mounts are flipped to get the seats as close to the centre as possible. The 1000 lakes aren't that narrow, I thik it's more a function of the straight up and down side mounts. The standard Recaro mounts have a bend in them, which I think precludes flipping them to offset the seat.
In both the RS Replica and this IROC project the seats are close to touching in the centre.
http://forums.pelicanparts.com/uploa...1245370041.jpg
Bill Verburg 06-19-2009 05:13 AM
I went through this this past winter, I purchased sidemounts from BK, Recaro(2 different kinds) and Speedware the only current sidemounts w/ a bend are from Speedware.
sabeo.m 06-19-2009 08:52 AM
Subscribed...
Great project! :D
EarlySport 06-22-2009 05:21 AM
A quick update;
Door panels are now in place. Eventually the pull straps will be swapped for mexico blue versions. If you look carefully you'll note the pull straps are further back than normal - long story, but basically these are early car versions that have been modified, and hence the bellcrank position was moved rearward to suit on the door skin. Door tops have been trimmed in suede to match the dash. Door lock buttons have been deleted.
http://forums.pelicanparts.com/uploa...1245673049.jpg
http://forums.pelicanparts.com/uploa...1245673083.jpg
Outer door handles are being re-fitted too. This is the passenger one - we don't need no steenkin' key locks!
http://forums.pelicanparts.com/uploa...1245673152.jpg
And just as a sneak preview, here's the car sitting on it's wheels after a 30 minute shakedown drive..
http://forums.pelicanparts.com/uploa...1245673271.jpg
sabeo.m 06-22-2009 10:10 AM
Right on! Super wicked!! :eek:
EarlySport 07-25-2009 04:34 AM
A final post showing some finishing details.
An oil breather catch can is important for track use. This is an off the shelf ricer product, but fitted my desired mounting location well.
http://forums.pelicanparts.com/uploa...1248521159.jpg
A lightweight sealed battery designed for a Harley motorcycle is used. A fabricated aluminium mount keeps it secure. A two pole battery isolator switch is on the ground. I may swap this for a four pole at a later date.
http://forums.pelicanparts.com/uploa...1248521340.jpg
The suede headliner was in place some time ago, but this is a better shot. It also shows the underside of the fibreglass sunroof replacement panel, trimmed underneath in lightweight carpet. My sunroof insert weighs 1.5lbs.. Eventually I want to do a carbon version.
http://forums.pelicanparts.com/uploa...1248521452.jpg
The final touch for the exterior is the custom carbon reflector replacement. A sticker was used as a mask, and the panel painted in mexico blue. Removal of the sticker and then clear coat results in the raw carbon showing through the Porsche script.
http://forums.pelicanparts.com/uploa...1248521559.jpg
Finally for this post here's a shot of the engine bay complete.
http://forums.pelicanparts.com/uploa...1248521610.jpg
EarlySport 07-25-2009 04:44 AM
Finished!
Finally the project has come to and end, and stage two of the fun begins - driving ;-)
There is always more to do, and continuing development, but for now the IROC is going to see some track time on Aussie circuits. It debuted two weeks ago at Wakefield Park in NSW, and despite some pretty severe weight jacking as I had no time to corner weight it, the car was a blast to drive and quite fast. Of 50 odd cars entered in the Porsche Club NSW super sprint, I ended up 12th outright and 2nd in class - not bad for a shake down run. The car is very predictable to drive and responsive. All the makings for lots of fun!
Here's some shots I snapped today after a quick wash. I still haven't colour sanded the paint and buffed - that'll come prior to a concours event in October. You'll also note no exhaust tip - I'm fabricating a new one.
http://forums.pelicanparts.com/uploa...1248522079.jpg
http://forums.pelicanparts.com/uploa...1248522145.jpg
http://forums.pelicanparts.com/uploa...1248522204.jpg
http://forums.pelicanparts.com/uploa...1248522243.jpg
911nut 07-25-2009 04:45 AM
Congratulations. That is a very cool project!
EarlySport 07-25-2009 04:47 AM
http://forums.pelicanparts.com/uploa...1248522322.jpg
http://forums.pelicanparts.com/uploa...1248522360.jpg
http://forums.pelicanparts.com/uploa...1248522397.jpg
Flieger 07-25-2009 01:38 PM
:cool:http://forums.pelicanparts.com/suppo...s/beerchug.gifhttp://forums.pelicanparts.com/support/smileys/clap.gifhttp://forums.pelicanparts.com/support/smileys/wat3.gif
Bonza!
matty74 07-25-2009 03:33 PM
Hey Graig,
where did you get those rims?? Tempted to get the same set of shoes for my machine.
Matt
cameron.arnott 07-25-2009 11:56 PM
Really nice result Craig, well done!
MrPerkles 07-26-2009 01:49 AM
money shot and it looks great :p nice job well done ;)
tb912 07-26-2009 01:52 AM
Very tasteful. I dig it.
User Name 07-26-2009 05:57 AM
love it :cool:
otto in norway 07-26-2009 10:30 AM
Wicked look! :)
Very smooth..! I'm Impressed!
