jj4u3's Avatar
Question chin spoiler
would putting an after market S chin spoiler on my 911T give me more stability at high way speeds 65 - 70 or would it be a waste of money. Currently I have about 40lbs of extra weight in the front but it doesn't seem to help much. If I have a passenger with me 180lbs it seems to help. If there is much wind it seems worse also
911 - 1972T
Old 01-09-2008, 05:12 PM
kilodawg's Avatar
I'm sorry I can't answer your question specifically because my '73T doesn't have an S spoiler (although I want to add one purely for the look).
However, I don't have any stability problems at the speeds you are talking about either. I'm just wondering if there might not be a specific cause for your problem other than aerodynamics...
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 01-09-2008, 05:21 PM
joe payne's Avatar
I added a chin spoiler and a duck tail to my SC and it made a huge difference. Any way you can reduce air getting underneath the car should help you over 60-75 m.p.h.
jtp911
Old 01-09-2008, 05:53 PM
jj4u3's Avatar
I don't know what else to look for? It just feels like it is light in the front when on the highway. A windy day makes it worse. Maybe I am just not use to it. This is my first Porsche. It could also be the imediate response from the steering compared my Honda?
911 - 1972T
Old 01-09-2008, 06:11 PM
gtihop's Avatar
I had the whale tail on my SC, found the front end very light and unstable at highway speeds, although it did look good though. I put on the chin spoiler and it made a very noticeable difference at highway speed. Hard to believe a small piece of rubber would make that difference!
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 01-09-2008, 06:20 PM
kilodawg's Avatar
I think for this discussion we need to stick with the early cars and an S spoiler.
The steering is real light. I've heard it referred to as telepathic. Remember we are also talking about a car that is lighter than the later cars too. Add to that the 1970's aerodynamics and period wheels and tires and everything might be just the way it's supposed to be.
I know at highway speeds my '73 feels light and nimble but it doesn't float. Just goes exactly where you want it with minimal driver input....
Old 01-09-2008, 06:28 PM
Peter V
TexasPete2720's Avatar
Ketchup and mustard helps
VECCHIO EURO 82 SCWDP
2 Hogs & A Diesel Truck
Old 01-09-2008, 08:04 PM
Porsche Crest
Yes, it will help a lot, I know when we did this to a buddy's 71 (and a duck tail) it made a huge difference on the straight at the track.
Old 01-09-2008, 08:20 PM
Looking at the pic, it would help noticably to lower the front end... at least an inch.
That will decrease the amount of air getting under the front of the car. Spoiler will help as well, but it's too high.
Old 01-09-2008, 09:13 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
what tyre pressures are you running?
how old are the tyres?
might be something with that as well
just a few pounds of air makes a lot of difference I have found
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-09-2008, 09:17 PM
It should drive well at 90mph. If not tweak the suspension, tires, corner balance, etc.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-09-2008, 09:23 PM
