-   -   question on torque specs. (http://forums.pelicanparts.com/porsche-911-technical-forum/386573-question-torque-specs.html)
rnln 01-09-2008 10:49 PM
I have question on some of the torque, can someone please input, if you know.
1- the 2 big bolts holding each brake caliper:
2- the big bottom rear shock bolt:
3- the big top rear shock bolt:
4- steering wheel big center bolt:
Thank you in advance.
Bob S 01-10-2008 07:04 AM
If I remember correctly , the steering wheel nut is 36ft lbs....
Gunter 01-10-2008 08:18 AM
The year and type 911 always helps.
Wayne's Engine Rebuild book has the torque values in the back.
