T-Bolts for Metal Engine Grill???
Which T-bolts are the correct ones to use for the metal engine grills?
On our host's site, I see the plastic ones to use with the plastic grill but what about for the metal grills? If the plastic ones are to be used, which length?....my 1973 doesn't have A/C so do I use the short or the long ones? Also are 6 T-bolts used in total for the metal grill? I got a sweet duck from Sonjay and I want to make sure I use the correct bolts to mount the metal grill. Thanks!
Ayo Irpin, Ukraine!
The 72/73 metal grill should have the T bolts already. They are sandwiched between the stretcher bars which are rivited together. Actually they are just hex head bolts and not true T bolts. If they are missing then your grill sounds like it might have been "worked" at some point.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
I recall that it was in great shape so chances are good that the bolts are there. I'll still check the next time I'm at the shop.This is good news that I won't need T-bolts....it sounds like a few less things that I have to buy!
