Typical Salesman
jeffrey2's Avatar
Power Inverter for Radio
I have a CDR220 I'll be installing in my bathroom during my remodel...yes, I'm that much of a nut.
I have all of the bits/pieces EXCEPT a power inverter, AC to DC; I've purchased 2; 1 on eBay made for phone chargers...didn't have enough draw and couldn't power the radio on; the other is one for temp use, not meant to be plugged in my attic and left alone.
Question is...what type of inverter do I get and where? Radio Shack and Frys didn't bear much fruit...
Has anyone done this before or am I blazing a trail?
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 01-12-2008, 10:33 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
First up:...an Inverter is to create AC from DC.
A Power Supply is to create DC from AC.
So....if you want DC...which is what I suspect...just get a power supply that will put out the correct VOLTS at the amount of AMPS that you need.
If you are trying to run a car type radio on the bench, I would look for a supply that puts out at least 20 AMPS at 13.5 VOLTS.
If the radio has CD or DVD....make that 30 AMPS.
You are NOT going to be able to run that on one of those little wall transformer-type things that are normally used for the kids walkman or such!
Bob
Bob Hutson
Old 01-12-2008, 11:22 AM
3.2 CAB's Avatar
To change AC current to DC voltage you need a CONVERTER.
To change DC voltage to AC current you need an INVERTER.
Just getting the terminology correct.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-12-2008, 11:49 AM
gshiwota's Avatar
About 20 years ago my company used to build power supplies used to bench test car stereos. Some of these units were used to power retail car stereo displays - like those boards you see at Circuit City where they had dozens of car stereos you can demo.
These were switching power supplies that put out 12 volts @ 12 amps. I did a quick search on google, and it looks like power supplies with at least this output rating are fairly easy to come by. Here's one I found on my first google search. Note - I don't have any affiliation or experience with this brand or website.
http://www.westcoastmall.net/pyramid-ps14kx-12-amp-12-volt-power-supply/388/p
Thanks.
Gabe
'82 911SC Targa
'61 356 Karmann Notchback
Old 01-12-2008, 03:18 PM
Typical Salesman
jeffrey2's Avatar
Thanks Gabe, I dont know the proper keywords, so i don't quite know how to search. Type in power converter/ power supply and you get computer pieces...
Old 01-12-2008, 03:45 PM
gshiwota's Avatar
I searched using "12 volt switching power supply" as the keywords and I too got mostly PC power supplies. However there were a few hits for the type of power supply that would work for you.
I doubt there will be many choices for what you're looking for. Actually the link I posted above seems like a good price for this type of unit. This unit is also nice because looks simple - one power cord and one set of +/- terminals. You may also try searching by the manufacture or part number of the unit in that link - perhaps you can find a better price or similar units.
Good luck!
Old 01-12-2008, 04:23 PM
gshiwota's Avatar
I just did more digging... here's one from Radio Shack. This one should do the trick.
http://www.radioshack.com/product/index.jsp?productId=2103960&cp=&sr=1&origkw=power+supply&kw=power+supply&parentPage=search
Old 01-12-2008, 04:38 PM
Sultan of Sawzall
rouxroux's Avatar
Go to Ebay, then under Consumer Electronics go to "Ham Radio", "Accessories", then type in "Power Supply". I would suggest any of the Astron or Vista supplies...I've used them to run 2meter transcievers & amps for over 30 years...Good units.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 01-12-2008, 04:46 PM
