Question wheel lug lube
Is there anything other than optimoly one can use to lubricate wheel lugs and shoulders?
Old 01-09-2008, 11:27 PM
Fuchs w h o r e
I use Never-Seez.
Old 01-10-2008, 12:09 AM
burgermeister's Avatar
+1 anti-seize
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 01-10-2008, 03:00 AM
David's Avatar
If you have the aluminum nuts, I believe the consensus is to use oil rather than anti-seize.
Old 01-10-2008, 05:00 AM
I've never heard that one about oil. I've been using anti-sieze for 30 years with no issues (that I know of). Am I missing something?
Old 01-10-2008, 05:23 AM
Anti-seize...both on the threads and the round-face that touches the wheel...not oil.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-10-2008, 06:44 AM
David's Avatar
I stand corrected .
Old 01-10-2008, 10:38 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
send me a PM with your shipping address and I will send you out some - you'll love it, and its will be gratas!
Michael D. Holloway
https://5thorderindustry.com/
Old 01-10-2008, 10:40 AM
AutoBahned
RWebb's Avatar
As usual Wil is right. AND P AG put out a TSB on this.
Old 01-10-2008, 12:54 PM
rnln's Avatar
Hi Will,
how about the surface of the hub which touches the wheel? I sometimes used grease. someone said it's a nono, but the wheel sometimes sticks too hard to the hub.
Fat butt 911, 1987
Old 01-13-2008, 02:08 AM
Are the published factory torque specs still valid with anti-seize on the threads?
Does the TSB specify new torque values?
TIA
Old 01-13-2008, 08:25 AM
AutoBahned
RWebb's Avatar
no - use the same torque.
As Bruce Anderson explained in an article, the Optimoly does not change the torque spec. (the friction to tension relation that the torque spec. is based on). You can use HT or one other one, but I forget which one it was.
a search will (should) pull up the other Optimoly version & more tidbits.
To be honest I have used regular anti-seize when I couldn't find the HT, and I am still alive and kicking, (tho not kicking nearly as high as I used to).
Old 01-13-2008, 11:25 AM
Kistle's Avatar
What is HT? Is that "Hi-Temp"? Sorry for the rant, but I find it frustrating when someone goes to the trouble of writing two paragraphs and then abbreviates the one word in the post that matters. Rant off.
Thanks,
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 01-13-2008, 11:54 AM
AutoBahned
RWebb's Avatar
I have no idea. I don't even know if it is an abbreviation. Contact Porsche and ask them. Or contact Optimoly.
Old 01-13-2008, 12:21 PM
