the dreaded shreaded
After wondering what that slight ringing sound was in my left chainbox last week....then losing a tensioner and dragging a ramp through the timing gear...I have arrived at the resurection. Fortunatley, I broke all rocker arms and so no valves were bent. I was able to scavenge all detritus from the case and install new ramps and tensioners. Cams timed, everything bolted up and sure enough I still have a slight chain ringing sound during warm up. Once hot, the sound goes away. What could the chain be riding on that would ring (with rpm's) as a chain on metal sound?
did you do a leakdown after you got it running again? very unusual to not bend valves in a situation like yours. after all the piston has to hit the valve first in order to break the rocker. it can be ever so slightly bent, and therefore stressed , so the head might fall off later and kill your engine.
Geezus...the ultimate fear of every 911 owner. The dreaded tensioner failure.
You are obviously more of a man than me because I'd be in the ER with a brain hemorage. I can't see how it is possible to break the rocker arms off and not bend a valve either. That's one hell of an impact I'd say. Good luck finding the noise mine did it too before I tore my motor apart. Only when cold...very odd. Good luck, ------------------ Leland Pate ___'99 Dodge Dakota <-which pulls the "real" car ___'79 SC Targa Which hopefully will be back together soon... |
Actually, I have not done a leakdown yet...though I am curious as to what it would show. I did pour gas into the combustion chambers with the corresponding valves closed and had no leakage.
Upon running it, I have had no smoking whatsoever. |
| All times are GMT -8. The time now is 09:48 AM. |
