pbs911
Guest
Posts: n/a
Question Swing-plate bushing measurement needed
I picked up some sway-away adjustable swing plates and want to use the Neatrix bushings I currently have on my factory swing plates. If someone has a factory swing plate for a 78SC off, could you measure the outside diameter of swing plate where the bushing mounts. The diameter of the bushing areas on the sway-away swing plates measure 2" on the inside and 1 6/8 on the outer. I am hoping to compensate for any differences before removing the factory swing plates. Alternatively, does anyone know the inside diameter of the Neatrix bushings? Thanks.
Paul
78SC Targa
Old 03-28-2001, 03:42 PM
911pcars
Guest
Posts: n/a
Post
The ads say the Neatrix bushings won't fit the Sway-A-Way adj. swing plates. If you're able to get them to fit, let us know.
Old 03-28-2001, 08:09 PM
