82 SC Rear Deck Latch
Anyone have any quick tips on adjusting the latch on the rear deck of an 82 SC?
The deck appears to sit flush but does not latch. Thanks in advance. |
any ideas?
The ajustment is the spring latch on the lid. If you look at the tip it is slotted for a screwdriver. Loosten it until you get it to latch
You also might try some pb on the lower mechanism maby its just sticking open
This happened to me recently...turned out to be just dirt and gunk keeping the mechanism (lower) opened. Applied a generous amount of WD40, used a metal pick to loosen the dirt, and wiped. It's working perfecly now.
| All times are GMT -8. The time now is 11:42 PM. |
