-   -   Turn signal center return spring. (http://forums.pelicanparts.com/porsche-911-technical-forum/387357-turn-signal-center-return-spring.html)
kfosburg 01-14-2008 11:56 AM
Does anyone have the specs for the little return spring on the 71 turn signal switch? It's the little spring that returns the turn signal to center after you have completed your turn. It's about 1/2" by maybe an 1/8" diameter.
I've had a hard time finding one at a normal auto parts store (mostly because they are tards and can't find anything unless it's "in the computer"). I tried an RC car throttle return spring, but it's a little too long.
Will one of the other springs work? See (#5 and #4):
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_70_73_KATALOG/903-20-Frame3.htm
Thanks,
Karl
