Tips for CV Joint Bolt Removal
Hello,
Hoping there might be some tips/tricks to getting CV bolts to back out without rounding out. I'm "nothing is ever easy" guy, so I'm anticipating the worst. Mine are the six internal wrenching hex bolts on a 76 930. Is a Craftsman bit OK, or do I need a higher end bit? Impact wrench or regular ratchet? If they do round out, how ugly is the fix?
Thanks huge, Tom
Old 01-22-2008, 06:49 PM
don911's Avatar
Some of mine rounded out. I used a vice grip on them with no problem.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 01-22-2008, 06:52 PM
Ensure the wrenching feature (hex socket) is completely cleaned out so the bit will fully register. Craftman bits are fine as long as they are in good condition. Apply axial pressure to keep the bit seated while applying the loosening torque.
Old 01-22-2008, 07:09 PM
Tim K's Avatar
+1
I attach the 12 point tool to a 3' long extension, give it a good couple of raps (brass hammer) to seat it and apply LOTS of axial pressure while slowly breaking it loose with a ratchet. Be very sure to keep it square to the bolt. I suspect that a couple of sharp blows helps break it loose. If you do round them out, it may have been a PO that boogered up the bolt head. +1 on cleaning it out. It'll also give you an idea what you're up against.
Good luck
Tim K
Old 01-22-2008, 08:20 PM
Tim K's Avatar
Oh ya, I've had good luck with vice grips in a pinch.
Old 01-22-2008, 08:21 PM
+2 on the vice grips while you're trying to loosen them. If you get to where you feel like you're in danger of rounding it, stop & put the vice grips on it & continue on with the hex wrench & vise grips together.
Marv Evans
'69 911E
Old 01-22-2008, 09:27 PM
Just wanted to say Thanks! Used this advise and all the bolts came out without a hitch! One more question though: Do folks use gaskets between the boot flange and the CV joint and between the CV joint and the stub axle/tranny flanges? Mine had no gaskets between joints and axle/tranny flanges. It did have gaskets between boot flanges and joints. Thanks again, Tom
Old 01-23-2008, 04:31 PM
If I understand you right, the gaskets might be in the wrong position. My understanding is that the gaskets keep the grease from being spun out of the joint. I fill my cv boots slightly with grease so that as it heats up and liquifies, there is a pool of grease all the time in the bottom half of the boot and therefore in the joint. I think with no gasket, the grease can leak out of the outboard end of the cv joint, especially when the grease gets really hot and turns to a liquid.
Old 01-23-2008, 05:17 PM
911 tweaks's Avatar
does anyone have or know of the thread or specifically, what are the bullet proof bolts to use in place of the factory ones? Are they a 12 pt. McMaster Carr bolt?
HELP!! I am also doing this now and wish the help from whomever can help me find this info as I stripped 4 in my removal and want tore assemble with these better bolts.
Thanks and sorry if I may side track your post... you may want to also upgrade to these bolts if we can find them now.
Thanks all!
Bob
I live for 911 tweaks...
Old 01-23-2008, 05:31 PM
Registered Abuser
MT930's Avatar
It seems to help if the female in the hex bolt is clean with no gook. I blast it out with brake clean. Works like a charm. Avoid rounding the out at all costs. Vice grips work well if it happens.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-23-2008, 06:08 PM
RETIRED
Joe Bob's Avatar
Clean and give the tool a sharp tap to seat it.
2012 ML350 3.0 Turbo Diesel
Old 01-23-2008, 06:17 PM
Tom, The '74-77 illustrated factory parts catalog shows a gasket (PN 930.332.297.00) of both sides of the CV-joint for a '76 Turbo. This may be confirmed by noting if the sheet metal flange the rubber boot is crimped into lifts off the CV-joint per se. Therefore you are likely to require eight of the gaskets (four per side or axle) if you elect to replace them all.
Old 01-23-2008, 06:44 PM
Bob, The factory (OEM) CV-joint bolts are strength class 12.9 alloy steel. This is the highest strength class in common metric fasteners. One has to get into the exotic "Aerospace" type alloys to do better. If properly installed and tightened (critical) the 12.9 strength class bolts are more than adequate. I believe our host sells the fasteners individually and you can get them from other vendors but often only by the box (typically 25). Mcmaster-Carr may sell them individually or in small quantities. What year and model is your car? What is the size (measure diameter across theads or shank) and length (from under the head to the tip of the bolt threads) of the damaged bolts?
Old 01-23-2008, 06:52 PM
Thanks Jim! I'll order that P/N gasket from pelican in the morning. One question though while your parts manual is hopefully still handy: Are the CV joints for the '76 and '77 930 the same P/N? I've seen joints listed for '77-'84 in some catalogs and '76-'84 in others. Hoping I've got the right ones ('76 same as '77).
Thanks again, Tom
Old 01-23-2008, 07:06 PM
This catalog only lists one CV-joint part number for the Turbo (and Turbo Carrera): 930.332.034.00 Was there a '77 911 turbo sold in the US?
I'll also look in an alternate catalog.
Old 01-23-2008, 07:25 PM
Non-grey market turbos were imported through the '79 model year. Next one was '86.
Per the abridged December 1995 Parts and Technical Reference Catalog the '76 though '79 turbos used the same CV-joint: PN 930.332.034.00
Old 01-23-2008, 07:34 PM
Thanks Jim! That's great news (already have the joints).
Old 01-23-2008, 08:02 PM
My CV bolts let go just after the throgs neck bridge in ny when i was heading to my house in nj. what a night that was.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 01-23-2008, 08:18 PM
AutoBahned
RWebb's Avatar
There is a long thread with recale on CV joints. It is well worth the effort to read thru. Be scrupulous about getting all grease out of the threads; use new Schnorr washers, torque and then re-torque after 100 miles. I suspect most failures are due to improper R&R.
BTW -- "It seems to help if the female ... is clean with no gook."
- That has always been been my experience also.
Old 01-23-2008, 08:49 PM
OldTee's Avatar
If it doesn't come the first time, I've had luck by tightening it the smallest amount. Tlhen loosen and out it comes. Apply pressure and don't allow the allen to slip. Use a 6" long allen.
Old Tee
all 911s sold
Old 01-23-2008, 09:31 PM
