Jon Green
Guest
Posts: n/a
Question Boge to Koni strut ball joint question.
Dear All,
I'm changing my worn out Boge front strut for a complete Koni unit (not just the insert).
I basically got a good deal 7 the complete strut was cheaper.
OK, I have a ball joint splitter so removal of the old strut is straight forward.
Is the old A-arm ball joint re-usable or does it have to be replaced as well?
If I need a new one has anyone ever had any success in removing the nut with a C spanner?
Or is the Pelican tool the only thing that will do the job, short of making your own tool out of a large socket as posted by Warren?
Cheers, JG
'76 2.7S
Old 03-30-2001, 01:19 AM
Early_S_Man
Guest
Posts: n/a
Jon,
My assuption has always been that removing the strut from the ball-joint stud damages the stud and sealing 'boot' enough to require replacement. Like con-rod and flywheel bolts ... reuse doesn't seem like a good idea, given the trouble and expense of changing a ball-joint by itself! The factory service manual specifies 15 mkp or 108 lb-ft for the slotted nut.
You might want to try one of your 'larger' independent UK specialty shops like Autofarm ... they may have the P 280b 'Slotted Nut Wrench' tool a lot closer than Automotion/Performance Products! Good luck!
Warren Hall
1973 911S Targa
Old 03-30-2001, 05:27 AM
Jon Green
Guest
Posts: n/a
Cool
Thanks Warren,
You've confirmed what I thought.
Probably/maybe OK to re-use, but not worth it.
Esp. as the ball joints have seen 116K already.
At least the sun is shining.
We've had around 5 months of non stop rain.
Cheers, Jon
Old 03-30-2001, 06:55 AM
