FinallyGotOne's Avatar
Quick Question for my 79SC911 LEAK
My 911 has had a lot of work done to get rei of all the annoying leaks. After summer was over there were no leaks, but now as it sits in the garage it has definitely started leaking. What is weird is the leak is coming from underneath the middle of the car. Basically right under the gear shifting area. I am wondering what could be leaking there? Any suggestions would be appreciated. Thanks!
Old 01-17-2008, 08:50 AM
3.2 CAB's Avatar
What type of fluid are you finding there? Motor oil, or transmission lube??
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-17-2008, 09:01 AM
tHE FLUID IS VERY THIN,, IT SEEMS MIXED WITH MOISTURE, PERHAPS BECAUSE OF THE SNOW WE HAVE BEEN GETTING. I'll try and take a smell today when i get home.
Old 01-17-2008, 09:03 AM
Only fluids in that general area are gasoline and brake fluid.
Definitely not anti-freeze.
Could also be that coke you spilled in the console.
Old 01-17-2008, 09:14 AM
Greek55's Avatar
What tcar said, except the coke would have left a powdery substance under the car.
Smoke
1982 911SC Rosewood
SCWDP # 0097
Old 01-17-2008, 10:09 AM
hmm.. okay, so it may be that the brake lines ruptured I'll check that fluid tonight. Thanks, Oh bythe way, I do not drink coke in there, for that matter i really can't drink anything in there.
Old 01-17-2008, 10:12 AM
Check the master cylinder, too.
Old 01-17-2008, 11:18 AM
Bill Douglas's Avatar
Do you have a cat?
Again, the smell test will work.
Old 01-17-2008, 02:28 PM
vash's Avatar
ok..what color is the fluid? you are not giving us much to guess with
poof! gone
Old 01-17-2008, 02:48 PM
