dbanazek
Guest
Posts: n/a
Post fuel level sender resistance
Does anyone have the factory spec for resistance on a 911 fuel level sender. Does it change over the years?
Old 03-28-2001, 05:37 AM
Early_S_Man
Guest
Posts: n/a
No, nichrome wire doesn't change resistance over the years! The slider may have 'opened-up' a bit, or developed corrosion on it, causing intermittent 'opens' ... but empty and full resistance values will not change! Corrosion on the plug/connector?
Warren Hall
1973 911S Targa
Old 03-28-2001, 07:43 AM
dbanazek
Guest
Posts: n/a
Post
Thanks for the help.
The does it change over the years was meant to mean did different years use senders with different specifications. I am trying to find the right values to put a sender in a fuel cell.
Old 03-30-2001, 04:49 AM
Early_S_Man
Guest
Posts: n/a
No change in specs from '65 thru '89 911, 912, or 930. The C2/C4 from '89 thru '94 used a different sender.
Warren Hall
1973 911S Targa
Old 03-30-2001, 06:28 AM
dbanazek
Guest
Posts: n/a
Post
many thanks
Old 03-31-2001, 09:49 AM
