GB83SC
Guest
Posts: n/a
Question Oil drain plug ?
My 83SC has a single drain plug on the bottom of the case, I see alot of posting about SC with sump screen and older style round plate for the drain. Did they change the plug for late 83'S or is mine a factory fluk ?
Thanks.
GB83SC
Old 03-30-2001, 07:10 PM
rstoll
Guest
Posts: n/a
Post
Your sump screen will be inside the plate that the drain plug is screwed into. There should be 8 nuts that hold this plate on. You will want to get the two gaskets for this plate before you remove it to clean screen.
Robert Stoll
83 SC
83 944
Old 03-30-2001, 07:32 PM
Early_S_Man
Guest
Posts: n/a
GB,
Not a fluke, just a mid/late-year change to the Carrera crankcase design because the old molds wore out before SC production ended! So, you got the one without the strainer!
Warren Hall
1973 911S Targa
Old 03-30-2001, 07:46 PM
GB83SC
Guest
Posts: n/a
Post
Thanks Warren, that has my suspicion.
GB83SC
Old 03-31-2001, 05:06 PM
