After the next project
Help with Brake removal
I have attached a picture to help. I am trying to remove the "dust cover" on the front brakes of my 930.
I need to get this off to have access to release the hub and rotor from the spindle. There are threads in that center hole. Do I need to thread something in there and then twist to remove or should it just pop off? As you might notice from the picture, I have been trying to remove with pliers. This does not look like a normal dust cover and wanted to see if someone could help me. Please tell me how to get this thing off. Thanks, Bryan ![]()
930 Dust Cover Removal.......
You need a long bolt to thread to it to get good leverage. A slide hammer with the correct bolt at the end will do the job. Pliers will be very difficult to get this thing out. A steady 'pull' force is what you need to slide this cap out.
Tony |
Thanks Tony,
That is what I was looking for. Do you know the size? Is a M10x1.5? I'm guessing the slide hammer that your talking about looks like a "U" that you slide along the bolt that hits the nut on the end to apply the "pull" force needed to remove correct? Thanks again, Bryan |
