Decolliber
Guest
Posts: n/a
Question Oil Pressure
From searching past threads I have learned that oil pressure should match RPM (viz., 3 at 3000 RPM). When I start my Carrera, the oil pressure goes immediately to 4-4.5 and stays there as long as the engine is running, irrespective of RPM. Is this bad? If so, whats wrong, and does it need to be fixed?
John C
1988 Carerra coupe
1957 Speedster replica
1997 A6 Avant
Old 03-28-2001, 08:53 AM
88911coupe
Guest
Posts: n/a
Post
Does it stay pegged at the top or does it flucuate a little with rpm changes? I had a bad oil pressure sending unit on my 87 and it would peg at the top as soon at the engine got power and stayed there. It should run higher for a few minutes after start till the oil warms up a bit.
Buck
Old 03-28-2001, 08:58 AM
Decolliber
Guest
Posts: n/a
Post
It just stays pegged at about 4-4.5 and does not appear to fluctuate with RPM.
Old 03-28-2001, 09:04 AM
JDaniel
Guest
Posts: n/a
Post
I would say that there is a problem with your sender/connection. I've got the same oil readings (pegs at the top). I bought a new sender last year (after testing to make sure it wasn't the guage or connection) but have been unable to replace the unit. I've read of a few people that managed to DIY, but after several hours of head scratching I resigned the job for the upcoming year. If you don't have an A/C mount then the job is relatively easy...
Dan Tolley
1987 911 Coupe
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294
Old 03-28-2001, 09:18 AM
Pillow
Guest
Posts: n/a
Post
The VDO guages work on a grounding ohm resistence system.
In this scenario either your sender on the engine is screwed up or the guage itself has a bad ground wire on it.
Also the bar pressure number does not exactly match the RPM. I think the thing to check for is either 3 Bar at 4000RPM or 4 Bar at 5000RPM with a warm engine, one of those two should tell the health of your oil pressure.
Good Luck,
Old 03-28-2001, 09:28 AM
Marshall Reddin
Guest
Posts: n/a
Post
JDaniel
Almost certainly the sender is defective. And, easy to change, with the right tool. I tried a borrowed 15/16 inch SnapOn crowfoot, but it didn't work - too thick. I then bought a 15/16 inch Craftsman crowfoot which is a bit thinner, and presto, did the job, without removing the AC mount. I did remove the oil Temperature sender, to provide a bit more room. You can also get a cheapie, Tiawanese 15/16 inch open end wrench, heat it, and bend it almost 90 degrees about one and one half inches from the end and do the same thing! Try it, and save yourself a trip to the dealer at $$$ per hour.
Marshall
Old 04-01-2001, 09:46 AM
JDaniel
Guest
Posts: n/a
Post
I have the craftsman crowsfoot. For some reason I was unable to get the wrench around the base of the sender. It could be the angle of the sender base... it could just be me. The car is still in storage right now, but after reading several posts on how "easy" other Carrera owners found the replacement to be, I will make another attempt later on.
I seem to be in the "just waiting to get the car out of storage so I can install all theh goodies ", mode . I'm really anxious to bolt on the GHL muffler...
Dan Tolley
1987 911 Coupe
Old 04-01-2001, 10:13 AM
