Sticky exhaust gaskets
I'm in the process of installing a CAT bypass. After removing the original CAT a good portion of the metal gasket stayed on the cross over pipe. I've been hitting it with a sanding disk to remove it but some of the material is hard to get at. Question: How important is it to get all of that off? With a new gasket smashed in there upon instal of the bypass pipe is it critical to have that surface very flat since right now its not a perfect plane.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
1984-911 M491
I had the same problem when installing my new exhaust system. I soaked the areas with WD40, then went at it with a sharp chisel and knife. Take your time, remove as much of the material as your can.
1984-911 TLC......SOLD |
When I had to remove my exhaust for some repairs, there was a fair amount of crap left on the flanges. I used one of my angle grinders, it took it about 5 seconds to freshen the gasket areas. I keep 4 angle grinders, each set-up for different purposes when I weld. The new gasket will compress into some fairly rough areas, but if you get it fairly smoothed out, it should work alright. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
abit off center
You can use some Mapp gas to heat it up, most the heat should go into the old gasket then it should come loose.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
light, slightly angled blows from a small ballpeen hammer usually work. chips right off.
Gents,
The chisel and BFH worked like a charm. Thanks for the tip. I was about to take the sanding wheel to it.
