Nitrometano's Avatar
Electromotive Question
Hello guys,
This is not a Porsche specific question, buy maybe I can find the answer here at Pelicans. My 911T use Webers, no EFI for him. I really like the carbs. Here is the problem:
I have an Electromotive Tec2 computer installed in my other car. that is a 1991 Mazda RX-7 Turbo with a bridgeport engine. This rotary engine uses primary and secondary injectors that fire in a staged feature. The question that I have is there is any posibility to have the staged feature using the Tec2?
I have the Wintec2 program already installed in my laptop. This program shows a GPO output that can control some electrical things likes NOS, shift light, aux fuel pump, cooling fan, etc., but it dont have any specific setting for staged injectors. The Tec2 that I have uses a double crank sensor that are installed a few degrees one from the other on the engine pulley.
The reason that I need this feature is that I need to install bigger injectors at the secondary position to have enought fuel for the engine needs.
If you can help me with some information about that I can do, would be great.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 02-20-2008, 08:31 PM
