how to remove door lock knobs??
Replacing some broken door hardware, and I want to pull off the door lock knobs-not the levers on the top, but the knobs you twist on the door pannel-I need to get the plastic knob off to replace the broken surrounding trim
How do ya get this knob off?? -Adam |
Pry the center disc off - there's a philips screw inside. Careful prying though - don't booger up your parts you intend to put back on!
So the knob has a cover that pops off-and then you can get at a screw to remove it?
Yes it has a center cap with a slot to pry it open if you look closely.
Amazing, Thanks Guys!
-Adam |
| All times are GMT -8. The time now is 08:48 PM. |
